HID fog light question
I searched but I didn't find much threads about this topic (fog light). So, please post the brand of your HID Ballasts, bulbs along with color temperatue, how much was the whole kits, and where/when did you get it? Thank you.
Got an Xtec 6000k 9006 bulbs. Bought it off a guy on ebay for $190. I put a double-sided tape and mounted the ballast under neath the stock headlights one.
Light is much bluer than stock so now I need to get a 6000k d2r for my headlights to match the fog.
Originally Posted by khoifl
Come on, should be more people have HID fogs light than 3 people.
8000k blue
6000k looks white for the most part with a hint of purple hue
4300k stock bulbs white
3000k yellowish never seen it in person
it seems most ppl say mcculloch suck but there are those that have had no problems with them.
are you looking to spend a certain amount of money? or you want used or new?
Originally Posted by Bxscig
It is all about the same price, what are you looking for or you just want to see what everyone has?
the new philips kits are expensive. what i usually do is check forums or ebay for used sets. i even get it seperate, find a good deal on a set of used hella or philips ballast or new then get a new set of bulbs for 4300K philips 9006 it is like $100.
ballasts used can go for $150 or so to $200 where $200 should really be slightly used like a couple of months?
fog light mod
If some of you have pictures of wiring diagrams of where you installed your ballasts and how you routed the whole hid fog light mod, etc, that'd be much appreciated
I just bought CATZ HID 4300k 9006 hid lights, and I wanted to install them on my 2ndgen TL, just didn't wanna start the install until I was 100% ready. If some of you can just give me some hints/tips/instructions on where you installed parts and what to look out for, I might just install them tomorrow
Would be much appreciated
Dragging knees in
TechOne 8000K, simple plug and play installation. 290 shipped brand new, one ballast went bad, replaced under warranty. I love them... although cops seem to love them, too. They attract a lot of attention and cops shoot radar at me... bright HID foglights = reckless speeder, I guess.
I put my HID ballast underneath stock one. There's a shelf that will fit the ballast nicely. I secured the ballasts w/ some double sided tape. Otherwise, everything is plug and play.
A lot of people hook up the hid kits plug-n-play into the stock fog harness because it is the easiest. I always have suggested against it only because over time the wires will be burned and it will start having problems.
There is 150Ws or so of power going thru those tiny wires for a few seconds during the startup, which is 3 times more so than expected from factory bulbs. If you hook up the hid kits via a thru a relay sysyetm with higher gauge you will
1. No flicker on the HID startup or trouble starting up
2. No flickering when on like when the wires are starting to burn out
3. Fuse to protect ballast
4. Peace of mind
Also, if you do the fog light mod and they are hooked up to your parking lights.... I woudnt leave them on and unlock your car, otherwise they will blink with the parking lights when the headlights are not on. If the fogs are off, they you will have no issues with this when unlocking or locking.
I have it done differently so I wont get this problem.
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
