HID converson
Old Feb 23, 2005 | 09:02 PM
gammo5's Avatar
HID converson
Looking at a HID converson for the high beams... Those that have done it, what brant would you recommend and where get ?
Old Feb 23, 2005 | 09:26 PM
akinaboy's Avatar
Wow.. I hope you use high beam a lot.
Did you already get one for fog lamps?
IMO, PHILIPS kit is the best. or kit with hella ballasts with philips bulbs. 3000k golden ion color hid is available and they are pretty hot.
Old Feb 23, 2005 | 09:45 PM
gammo5's Avatar
yup... live ne wi... lots of rural driving... know of where i can get a good converson system????
Old Feb 23, 2005 | 09:47 PM
akinaboy's Avatar
I do have replacement bulbs, but not the whole kit for 9005 high beams.
Probably Ebay would be a good place?
Old Feb 23, 2005 | 09:52 PM
gammo5's Avatar
thanks for your help... i will take a lot at ebay
Old Feb 24, 2005 | 12:57 AM
Jaadu's Avatar
Its not a good idea to use HID's in the high beams unless you plan to leave it on for a while. The constant flickering of the HIGH BEAM on and off will ruin the ignitors. So if you plan to leave it on for a while then alright.
The new cars inlcuding the 3rd Gen TL's use a different mechanism to get the HID's in the High beams (bixenon0. Its a metal flapper in the headlight that opens up allowing light to be shined out higher giving it that high beam pattern. But essentially using the same ignitor and HID bulb.
Old Feb 24, 2005 | 08:20 PM
Mr Hyde's Avatar
Yup. If you go HID's for the high beams, you'll give up the ability to flash your high beams. If not, you could damage them.
I bought a conversion kit for my driving lights, and they made a big difference in lighting with no sacrifices. There was no glare, and they could be left on whenever needed. Just mount the ballasts properly, I put them under my headlamps to keep them away from puddles and water.
Jul 16, 2017 07:33 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
