HID conversion question
Old Sep 13, 2004 | 02:05 PM
55M2G7L's Avatar
I want to replace my stock 4300k hids with 6000k hids, i was wonderin, can i just change the bulb or do i gotta get a new set up?
Old Sep 13, 2004 | 03:50 PM
SHINY TL-13's Avatar
GO TIME
you already have the stock setup for HIDs so you just need bulbs. Check out plasmagarage.com
Old Sep 13, 2004 | 03:58 PM
BdasAcuraTL's Avatar
D2R is the direct replacement... but if you want t just a little bit more brighter then go with D2S type bulbs which are for projector headlights (just keep in mind you would have to modify those to fit and also there goes your cutoff line)
Old Sep 13, 2004 | 03:59 PM
Type S Desi's Avatar
Nope just bulbs... many of us including myself have done this. Very easy. When and if you want to convert your fog lights from stock to HID then you need to do bulbs and ignitors. And if you seek more information, just try doing a search, this topic has been covered way too many times. I'm sure you'll find all the answers and all other usefull info that way, much quicker.
Old Sep 28, 2004 | 03:47 PM
El pana/TL32's Avatar
Based on your answer, will our bulb (D2R) fit an Audi A6 or BMW OEM projector set up? or even an aftermarket, like those by TYC Elegante for the accords 98 - 02?
Thanks!
Old Sep 28, 2004 | 05:05 PM
Bxscig's Avatar
Just change the bulbs, make sure it is the same base... D2R... D2S can fit with modifications
Old Sep 28, 2004 | 07:40 PM
Thanks!
Old Sep 28, 2004 | 08:00 PM
shawn744's Avatar
Kollage is funn!
the best place to buy bulbs are HIDKING.com....i got my pair of 8000ks (which IMO are the best looking color) for $135....check it out. -shawn
Old Sep 29, 2004 | 02:19 AM
ju6ganutz's Avatar
great price but are they just as bright as the stock bulbs? do you have pics?
Old Sep 29, 2004 | 05:45 AM
mrsteve's Avatar
I'm sure you know this, but the stock 4300k is the whitest you are going to get. Anything above that starts to turn more and more blue. Blue =
Old Oct 25, 2004 | 01:11 PM
Bxscig's Avatar
6000k is not noticable when u look straight at it alone. only slightly when placed next to a 4300k. 8000k is no doubt blue
Old Oct 25, 2004 | 06:38 PM
shawn744's Avatar
Kollage is funn!
if you're buying JUST BULBS, the best deal is HIDKING.com.......other than that, their kits seem to be a bit pricey.....
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
