HELPPP on LED bulbs!
Does anyone know a retailer in california or online that supplies 194 blue LED bulbs? I think these are the bulbs that are replaceable with the door courtesy lights..
Also, does anyone know how to safely pry off the dome light? I've been pickin at it, but its not budging; i'm afraid i will damage it or something
THANK YOU :tflamer:
THANK YOU :tflamer:
Need a WHAmbulance
Here is a link to a place that has 194 Led's.
http://www.sounddomain.com/
To get the dome light cover off, pry with a small tip screw driver on the front corners/sides.
I'd rather be driving:
So I'm not the only one who had a b*tch of a time trying to remove the dome light lens!!!! :smackhead
I couldn't figure out a way of removing it without gouging up the plastic base so I copped out and bought a new lens from the dealer ($4 I think). I then used my Dremel tool cutting wheel to rip a hole into the lens and then pull it off with a pair of needle nose pliers. Replaced the bulb, put the new lens on and VOILA! good as new!
I put a POLARG hyperwhite bulb in the dome light to match the PIAA white LEDs I put in the map lights and door lights. BTW The map light lens came off the same way as the dome light lens (another $4 from the dealer). :grenade:
I'm done with interior lights for a looooooooooong time. :smokin:
just so you know 921 led's will work as well. i got mine from www.autolumination.com each bulbs has 9 leds. they fit perfectly into the door lights and map lights. next i n eed to see if they will work for the parking lights.
ripit
09-26-2015 06:19 PM
