HELP - Stuck in 4th Gear
Old Oct 24, 2006 | 12:34 PM
pdpgsr's Avatar
7th Gear
Hi i have a problem. When i Throw the car in drive it is stuck in 4th gear (starts off at 4th gear from 0 mph) from what my mechanic told me. It drives normal if i shift manually (not shiftronic) using the d1 to d2 to d3 etc. but wen i throw it in d4 it seems to be always be there. my mechanic told me he needs to check the wiring first see if theres a short in the wires. if thats not it he needs to replace the ecu. I told him not to do anything yet. this is because i wanted to get some advice on what you guys think it might be? the mechanic also check the silenoids and told me thats not the problem. ADVICE?
Old Oct 24, 2006 | 01:39 PM
fla-tls's Avatar
On the way!
Interesting, 4th gear is all shift solenoids off. This sounds like an electrical problem. This may sound like a dumb question, but do you have a check engine light on? Is the transmission plugged in to the PCM (and no rats made a nest in the wiring harness)?
Can't this guy hook up a scanner to the car and drive it while monitoring the data coming from the PCM? He can see if the logic side of the PCM is working by that.
Old Oct 24, 2006 | 03:58 PM
pdpgsr's Avatar
7th Gear
check engine light is on. the guys said its not a wiring problem because he checked all the wires. and it wasnt a ground problem. which only leads to one thing. the ecu.
Old Oct 24, 2006 | 04:05 PM
fla-tls's Avatar
On the way!
What were the codes stored inside - did he tell you?
Old Oct 24, 2006 | 04:08 PM
pdpgsr's Avatar
7th Gear
he ask me how long i owned the car i told him 6 months. and told me that the guy before me and put in a new ecu a performance ecu or something, because he called up honda and the numbers on the ecu does not match. i am just wondering if there really is a thing called a performance ecu for our tl?
here are the codes:
P1768
P0700
Old Oct 24, 2006 | 04:16 PM
Type_S's Avatar
It might be the ecu that's shot. My father had a legend that was stuck in 3rd gear and it ended up being the ecu as the problem.
Old Oct 24, 2006 | 04:21 PM
mrodriques's Avatar
P1768 Automatic Transaxle (Acura, Honda)
Here is a link for the codes
http://www.yotatech.com/showthread.php?t=27309
Old Oct 24, 2006 | 04:22 PM
mrodriques's Avatar
P0700 Automatic Transmission Control System
Old Oct 24, 2006 | 05:15 PM
S1CK TypeS's Avatar
B A N N E D
mine got stuck in 2nd gear the other day but after a few seconds and bouncing of the rev limiter it shifted into 3rd
Old Oct 25, 2006 | 12:26 AM
HittingDaLine's Avatar
All the way to redline
I hate that. I did that when racing a 350z...
Old Oct 25, 2006 | 01:09 PM
fla-tls's Avatar
On the way!
P0700 is a generic engine-side code that's worthless when diagnosing the tranny. It basically means "transmission problem"
Old Oct 25, 2006 | 01:15 PM
fla-tls's Avatar
On the way!
I've never heard of a "performance ECU" for an Acura. Maybe it blew out before because of wiring problems, so he replaced it so that his vehicle would "perform" until he traded it in or sold it.
Old Oct 25, 2006 | 03:45 PM
acurabum's Avatar
Try to reset the ECU then see if everything is back to normal ......
Old Oct 25, 2006 | 08:02 PM
S1CK TypeS's Avatar
B A N N E D
yea mine happend while i was racing a 3.5 maxi, looks like we got issues with nissans lol
Old Oct 26, 2006 | 05:14 PM
pdpgsr's Avatar
7th Gear
if the car shifts fine in manual mode it means nothings wrong wif the transmission right? it just means that the tranny is just getting 4th gear as the signal right?
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
joflewbyu2
Oct 8, 2015 11:16 AM
