help...stabilizer end link nut.
Old Jan 24, 2004 | 12:35 PM
joseph_99tl's Avatar
installing my comptech sways.
having akot of trouble removintg the end link nut.
i got it loose but it very difficult to turn.
it feels like the 5mm hex is going to strip.
i don't want that.
any ideas?.
help.
if i strip that stabilizer end link 5mm...i'm
screwed!.
put the car back together w/loose stabilizer nut.
Old Jan 24, 2004 | 01:10 PM
nick79's Avatar
mine stripped. i had 2 that stripped!!!!!!
Old Jan 24, 2004 | 01:11 PM
nick79's Avatar
first. get a friend to help you. put alot of wd-40 on the nut.
have your friend turn the nut while you hold the hex wrench in place.
i had the front one stripp and i had to use a saw to cut it. then a drill to remove it. i had to drill into the nut.
Old Jan 24, 2004 | 01:41 PM
but then did you replace the stabilizer link?..
Old Jan 24, 2004 | 01:54 PM
nick79's Avatar
yes i ordered a new link. i had to buy 2 links. one for the driver side front and the driver side rear.
Old Jan 24, 2004 | 02:07 PM
nick79's Avatar
i ordered the new link with a new nut. since it was new. it slided right in the link and was easy to install. my problem is i couldnt torque is correctly since it turned when i tigthened with the torque wrench.
Old Jan 24, 2004 | 02:08 PM
well.
this i'll have to wait.
did the replace have the same stupid 5mm
end, or something different?.
Old Jan 24, 2004 | 02:10 PM
you retightened later with a w/torque and it tightened more?.
right?.
Old Jan 24, 2004 | 02:12 PM
was the top nut on the other end of the link, easy to remove...easier...
right, this link has 2 ends.
Old Jan 24, 2004 | 02:56 PM
nick79's Avatar
the rear was easier, the front of the car was harder. i never did get to use the torque wrench since it keeps spinning. the replacment was exactly the same.
the top is easier, the bottom was crazy hard in the front. i just drilled thru the nut and broke it off.
Old Jan 24, 2004 | 05:59 PM
thx Nick79..
did u get part from Acura?..
eastcoastguy
Oct 29, 2015 03:00 PM
lanechanger
Oct 13, 2015 10:56 AM
Rcelestino93
Sep 23, 2015 10:01 PM
Brandle34
Sep 23, 2015 07:20 PM
