Help on shift gate light
Old Apr 4, 2009 | 06:45 PM
akad3m1kz's Avatar
The bulb is dead and I was wondering if anyone can tell me how to remove the shift cover and how to replace the bulb
thanks
Old Apr 4, 2009 | 07:17 PM
Slow Type S's Avatar
ARide for Life
just pop it with your nail. its extremely easy
Old Apr 4, 2009 | 07:44 PM
Razzi's Avatar
T-Swzy
pop the black plastic surrounding the metal shiftgate first.
as for the metal shiftgate itself. it's tricky. what i do is push it horizontally towards the passenger side as hard as i can then lift it up from the right side. it'll probably take a lot of back and forth nudging though
Old Apr 4, 2009 | 08:13 PM
akad3m1kz's Avatar
i was able to remove the plastic cover and all and im able to see the bulb but how do i get to remove that?? will i have to remove that big cover in order to get underneath of it or can i pop it out from the top?
Old Apr 5, 2009 | 08:08 AM
dtong_ck's Avatar
9th Gear
I have the same problem. I just bought a bulb from the dealer. However, I found that the shift knob is very tight. How do you unscrew the shift knob?. Another member told me the shift knob need to be out.
Old Apr 5, 2009 | 08:12 AM
fsttyms1's Avatar
You have to remove the clear piece that spreads the light out. then take a needle nose plires and pull it out
Old Apr 5, 2009 | 08:16 AM
dtong_ck's Avatar
9th Gear
fsttyms1: is it necessay to unscrew the shift knob?
Old Apr 5, 2009 | 10:18 AM
Razzi's Avatar
T-Swzy
yeah, un screw it. just turn it real real real hard to the left. it'll probably be set on here but turn it it's meant to come off. then you have to remove the silver shift gate too
Old Apr 5, 2009 | 02:21 PM
dtong_ck's Avatar
9th Gear
I had just worked on the light and also taken a video of how it is like. The plastic pieces are loose already. I just want to show how they come off. Hope it will help. Here is the link.
http://www.youtube.com/watch?v=2hj2T4bISKU
Old Apr 5, 2009 | 02:57 PM
my.daily'tl''s Avatar
Always Working In
Thanks for the help. Just got my TL. I didn't even realize there was a light in there! Thanks for the video dtong. I'm adding this to the diy list!
Old Apr 6, 2009 | 11:28 PM
akad3m1kz's Avatar
sweet thanks!
Old Apr 8, 2009 | 09:05 PM
Always Working In
Just a quick update. I got a replacement bulb from radio shack today and with a little tweaking I got it working. Thanks to everyone posting their tips.
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
BigJilm
Sep 21, 2015 08:32 PM
HeloDown
Sep 8, 2015 06:51 PM
