Help -remove panel- driver side -below steering wheel
Old Mar 6, 2008 | 01:32 PM
mzahidi's Avatar
i need to remove the panel that's below the steering wheel (drivers side)
I need to install some switches , but can't figure out how to remove it, i've removed the wood grain, and the side panels for the center console that give me accesss to the radio...but i need to remove the panel that has the ligthing dimmer on it...
thanks
Old Mar 6, 2008 | 02:23 PM
AcuraDreamin's Avatar
2000 Acura TL
If you look to the left side of your dash on the bottom, there is a little panel where most of the fuses should be, that should just pop off. When that pops off there is a screw that is holding the panel that you are talking about. Also dont know how you removed the side panel of the center console, because you shouldnt be able to take that off until you have taken the panel under the steering wheel off, from what i remember. But im pretty sure onece you remove that screw on the left side of the whole dash, the panel should be able to just pop off. Good luck, hope this helps
Old Mar 6, 2008 | 02:52 PM
VeEzy's Avatar
B A N N E D
-remove fuse panel
-remove 2/3 bolts ull see once u open the fuse panel
-remove harness from the switches connected to the lower panel
-remove a bolt on the right side of the panel(if there is one)
-then pull the whole lower panel down. (its clipped in)
Feb 25, 2020 09:57 AM
nanos
Nov 12, 2015 08:41 PM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
