Help Please!!
Old Feb 26, 2009 | 05:40 AM
rk5tar's Avatar
Help Please!!
ok i got 2 quick questions i need help with.
1. That woooosh noise my car makes after i turn it off; is it bad? (i have a CAI installed)
2. In the morning when im about to go to work after i back out from my drive way i switch it into D4 and right after it makes like a light vibrating noise, i would always think it was my fone that was sitting on the dash but it was'nt, does anybody know what this sound is??? it kinda sounds like when a phone vibrates when its in your cup holder. the vibration noice only last for a sec the comes on again after another second has passed and then i never hear it again.
im not really worried I just want to know what these noises my car is making are.
~Thanks
Old Feb 26, 2009 | 09:55 AM
acutee's Avatar
I think your cai woosh noise is normal, unless you have a leak
The vibration you explained is probably the ABS checking. Did you have that vibration all along, or it just happens recently? If it happens recently, you might want to check your engine front and side mounts.
Old Feb 26, 2009 | 10:05 AM
BensTLS's Avatar
Ditto! Check the engine's mounts.
Old Feb 26, 2009 | 11:33 AM
bigeshorte45's Avatar
its normal for your CAI to make that WOOOOSH sound when you turn the car off... also, i always wondered what that light vibrating noise is as well... i also hear it twice right after i turn my car on, then never again, must be normal
Old Feb 26, 2009 | 11:58 AM
acutee's Avatar
If it was ABS checking, the moment you drive forward about 10feet, it will make that vibration feel, then another few 100 feet it will make another one. That is absolutely normal.
Old Feb 26, 2009 | 07:38 PM
fsttyms1's Avatar
Normal and its normal. Its the ABS self test.
Old Feb 27, 2009 | 06:40 PM
rk5tar's Avatar
ok thanks alot i just did'nt want to have to worry about a problem later on. u guys rock
Old Feb 27, 2009 | 08:24 PM
nhn23's Avatar
I live in
this just solve my problem too.. that vibrating noise.. always wondered and now no worries. thanks guys
Old Feb 27, 2009 | 10:45 PM
bucsteve's Avatar
the woosh noise is normal with an aftermarket intake but i've wondered myself what the other noise was cause i hear that all the time. i never worried about what it was but now i know
