Help please.....
Help please.....
ok, i posted this in Parts and Performance and i didn't seem to get an answer....
help please...
https://acurazine.com/forums/showthread.php?t=138125
help please...
Pro Satisfied Ceramics with Factory Rotors, do you guys think it will be ok?
i've been reading around on the forum and everyone seems to be changing their rotors too.. and i was just wonderin if it'll be ok to just change the brakes and get the factory rotors spun. and with that setup, will it still improve the braking with just the new brake pads...
or would you jsut stick with oem brake pads?
I would change out the pads regardless of whether or not you change the rotors. I'm actually in the same situation where I'm feeling a lot of vibration while braking.
From the research that I've done the best priced setup for replacing everything is Rotora's with ceramic pads. If you replace the rotors there's not much difference between cross drilled and slotted. There are rumors and some horror stories of cross drilled rotors cracking. In this situation I'm sure the manufacturer would replace them for free. Apparently the ceramic pads cause less brake dust. Excellerate is a solid sponsor on the site who can hook you up with both.
Info on ceramic pads
Stock TL
for most the Brembo blanks are more than enough and have turned out to be a great choice. If your looking for a little bit better option the rotora and irotors are also the best of the oem replacement crossdrilled/slotted rotors for our cars this side of a BBK
Stay off my lawn!!
i've got a 2000 tl-p with ~90k on it and i doubt the rotors have been replaced (at least carfax didnt mention it) but I assume they are in decent condition. Also, if you dont mind, do you know of any springs that improve ride quality (drop height negligable)? Thanks man
