help painting calipers
I know there are a few people on here that have done it and I need some guidance.
I'm sure it's not that hard once you get the wheel off, but what kind of paint is the best. I know there is specific paint for calipers, but is there a better brand I should look for? How many coats should I do.
What is the process for painting them, how much sanding should I do, what grit paper, etc.
Any help is appreciated- I would like to do this tomorrow.
Also, what color should I do them. My TL is silver. I was thinking red. I saw Arn2000TL's and thought they looked good.
Thanks!
<A HREF="http://www.adamoski.com/acura.html" TARGET=_blank> </A>
Thanks!
O.G.
I would like to know also. I have a black TL so I think I am going to paint it black also. Thanks!
BTW, I think we should call Neil (NSXNEXT) since he painted everything on his TL.
Binh
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by BlackShadow on June 17, 2001 @ ]</font>
Binh
I'm doing mine black soon too!
*2000 Acura 3.2 TL
*Nighthawk Black Pearl
*35% tint all around
*Interior black light and piaa superbright door lights
*Burlwood Shift Knob
*Air Spencer air freshener
*H&R Sport Springs
*Acura front seatbelt pads
*WW Flush Mount Spoiler
*Chrome rear license plate frame
*Weather Tech floor mats
*More mods to come!!
*2000 Acura 3.2 TL
*H&R Sport Springs
Hurry and let me know. I was thinking of it too but I read the instructions on bleeding the brake line to removing them and then making sure they are remounted correctly.
Kind of freaked me out.
You gonna do that or just tape them off?
My bro did it to his car and he just covered everything but the calipers with grocery bags. He applied 3 coats of high temp paint and they are still starting to chip off a bit. Make sure you clean the calipers real good though. Also, i wouldnt mess with the brakes...its not neccessary.
This is what I am going to do. I bought some high temp caliper paint that can be painted on with a brush. It also includes a large can of cleaner. I don't have to remove or mask anything, and I will apply at least 3 coats of paint per caliper. Also, do it in the shade and make sure to let it dry for at least a day. Good luck to all, I'll do it sometime next week!
*2000 Acura 3.2 TL
*H&R Sport Springs
*2000 Acura 3.2 TL
*H&R Sport Springs
Tom
2001 Nighthawk Black Pearl TL
Comptech springs,Xephyr,Performance CAI, Inspire tailights,Piaa super white 001 solitare fogs, Inspire fog switch,Burlwood shift knob,Piaa Xtreme white blinkers,Razo carbon fiber pedals,BEL 870 radar detector, Acura-TL.com sticker
do it yourself, !
Hey what kind of High temp paint did you find that can be painted on?? Can I get the brand? All I've seen here is the spray paint ones. Thanks.
2001 Acura CL Type-S
Black - Ebony Interior - Spoiler - 20% Tint - Cleared Headlights - Complete bulb replacement with Polargs
18" SSR GPO DeColte Evolutions on Nitto 555's - Comptech Headers - Eibach Springs
2000 Mercedes Benz E320
Black - Black Interior - Nav
warning please dont take of the caliper from the brake line.....
big mistake!
i had to drain the whole brake system completely and refilled again
once you unbolt the caliper from the brake line the oil will start to slowly leak out and once it does that(drop by drop)...your brakes are not goin to be as effective as before..at least it took me a while b4 the brakes started working like new again.
big mistake!
Acura3200 - I used Rust-O-Leum (Royal Blue) in the small can for my calipers. Used a small paintbrush and didn't remove one single bolt. Just taped off some parts.
Used Rust-O-Leum Hi-temp black (for BBQ grills) in the small can also (a small foam brush works good for rotor edges) for hub & rotors after I scrubbed the rust off Six months later and it still looks great - no chips or problems. Take your time and it will turn out perfectly.
Originally posted by Acura3200:
Thanks for the replies!
I'm going to be starting this around 2pm as long as I can find the paint.
BTW, do you have a day off from work today??
Y2K SiLVeR TL, non-navi
SLVR TL Homepage Last updated 6/9/01
Guest
Posts: n/a
I have a black Monte Carlo and I painted my calipers a green color. I put a plastic bacg around my disk and taped it around the caliper. I then taped up all the surrounding with blue painters tape. I then used a wire brush to clean off my caliper. Then I painted the caliper with white primer out of a spray can. I then put approx. 3 layers of the green (engine heat) paint on the caliper and let it dry. I bought the paitn at PepBoys (or Strauss). It came out good. There was a little sliver on the disc but it came off right away. Good luck! Let us know how it came out.
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
