help p0505
Old 02-11-2011 | 07:09 PM
victorvu's Avatar
Exclamation help p0505
i know what everyone is going to say so ill cut it short. I have a 2nd gen tl-s iacv was swapped from my 6 speed same problem, cleaned the old iacv same problem, bought a new one same problem. Bled the coolant same problem. It'll go down to normal idle but as soon as i rev it pass 1k itll start revving on its own. Either way im pretty sure it isnt the iacv. Can it be the vsa? should i clean it?
Old 02-11-2011 | 08:56 PM
01tl4tl's Avatar
TPS throttle position sensor has been known to fail on our car- try a search for that
you removed the iacv rod- and cleaned everything? correct?
no vac leaks- motor mounts good (vac boosted models)
Old 02-12-2011 | 11:12 AM
victorvu's Avatar
cant be either of what you listed. I have swapped the throttle body and theres a new iacv in there. motor mounts are good. This morning i took it on a 30mile drive and when i got back i scanned the car and got a p1739 code which says its the automatic transaxle. Please tell me its not the tranny. It shifts fine and drives fine other then the rpm surging.
Old 02-12-2011 | 02:51 PM
01tl4tl's Avatar
I gave you my best guess based on symptoms and not having any codes
new parts can be bad or installed wrong- I always ck the last things done,, first.
a 30 minute drive would be enough to clog the outlet screens with clutch particles IF thats your problem it could cause surging-rpm issues
how does the trans fluid look and smell- burnt sugar smell = bad news
take a 3 oz fluid sample and have tested- blackstone labs can tell you if the trans is wearing in any strange ways..bearings, clutches,,,
Old 11-02-2012 | 09:53 PM
BREWCITY1974's Avatar
Im having the same prob 00 rl i have replaced timing belt water pump iac head gaskets radiator thermostat bleed sys 5 time i also have no heat most of the time can anyone help me
feliks66
2G CL Problems & Fixes
09-27-2015 05:55 PM
Scottyknows007
07-02-2015 08:41 AM
sunset_2002tl
06-01-2011 04:58 PM
jzebrook
1G TL Problems & Fixes
04-16-2011 08:11 PM
bayonnebandit
10-04-2009 04:08 AM
Quick Reply: help p0505
