Help!! My Stereo Got Stuck And Code Is Not Working?
Old Dec 22, 2007 | 07:20 PM
Max Boost's Avatar
So I Got My Car Back From The Paint Shop, And The Stereo Is Locked, So I Called Planet Acura Like Allways Was No Help, I Got The Code Put It In But The First Time It Came Up With Error 1....? So I Figured I Didnt Put In Right, So I Tryed It Again... No Dice, So I Call The Dealer Back And They Said I Need To Go In So They Can Look At It, But It Will Be 60 Just To Look At It....anyone Have Sugestion???
Old Dec 22, 2007 | 08:14 PM
sfont012's Avatar
here comes the snow!
buy a new one!!
i have 2
the one thats installed and an OEM 6 disc changer with burlwood trim.
hopefully you figure it out without going to or paying the dealer! good luck!
Old Dec 22, 2007 | 08:27 PM
fsttyms1's Avatar
Originally Posted by sfont012
buy a new one!!
i have 2
Thats not good info at all.
sfont012
Many have had the problem, You may have to unplug the antenna out of the back of the radio then enter the code (yes it sounds like a joke but its true) then after it accepts it plug the antenna back in
Old Dec 22, 2007 | 09:10 PM
sfont012's Avatar
sorry, i apologize. my bad
Old Dec 23, 2007 | 05:08 PM
Max Boost's Avatar
how do i get to the anttena without riping everything out? what kind of stereo do have in your car now??
Old Dec 23, 2007 | 05:11 PM
fsttyms1's Avatar
You have to just pull the side panel off (remove the wood trim and remove the screws that hold it on. then you can reach your hand in there and unplug it.
Old Dec 23, 2007 | 07:58 PM
thisisnotdave's Avatar
Porkchop Sandwiches!
I found that sometimes you dont have to unplug it, just keep trying the code. If you get past er9 and lock, it then you can try the antenna thing. I took me 10 tries or something once, I dunno why, i think you have to be quick when you enter the code, but thats just my observation.
Old Dec 29, 2007 | 12:29 AM
go to ebay for code under 25 dollars and if t locks unplug car battery
Old Dec 29, 2007 | 09:14 AM
25 is a good deal but if you already uave a code thats worked berore ur just wasting ur money
Old Dec 31, 2007 | 07:49 AM
acitydweller's Avatar
two separate dealers gave me two differnet radio codes. this is truly frustrating and my car has been silent for 3 months now.
Old Jan 2, 2008 | 05:37 PM
AMGala's Avatar
Lamborghini Aventador FTW
Try to remove the radio fuse (located in the passenger side fuse box inside the car) for 15 minutes, put the fuse back in and try again.
Old Jan 2, 2008 | 11:57 PM
kushsmoker's Avatar
B A N N E D
this problem happens very often for tl/cl owners. Ive got to agree with fsttyms1, you have to unplug the antenna before you punch in the code. Just remove the driver side woodgrain panel and the panel under the steering wheel for the easiest access
Old Jan 3, 2008 | 01:09 PM
sfont012's Avatar
why not buy a new radio and get peace of mind!!!! for the money spent to fix that radio plus time and aggravation, your better off just buying a decent headunit that can actually play cd-r's and mp3's
Old Jan 4, 2008 | 08:52 AM
NYC TL Pilot's Avatar
NYC TL Pilot
sfont012
This is THE solution. This is what the mechanic at your dealer would do if you decided to have it looked at and fixed. Something about the antenna being grounded and messing up the code input, or so I was told. It is what I had to go through the when I got my car.
I did not know much about the TL at the time so I did not fiddle with it, and plus it was under warranty so, what the heck... didnt pay for it. It seems to be a common problem for TL (dont know about other models). but the guy knew exactly what was wrong and did his thing. 15 minutes and I had mine blasting all the way home....the end...
Old Jan 13, 2008 | 04:26 AM
Max Boost's Avatar
wow! i spent about 45 mins taking apart my hole center consel and it happen to be the dam antenna, i took it out and right wen i put it back in and put the code in that the dealer gave me it work . i love this site.
mada51589
Jan 9, 2025 04:40 PM
jamestheunderdog
Jul 19, 2016 07:58 PM
carz0159
Sep 20, 2015 06:11 PM
acurajj
Sep 19, 2015 03:47 PM
Gianni Formica
Sep 7, 2015 08:28 PM
