Help! My Car Is Idling Crazy!
okay so this morning i woke up went for a drive home....and i noticed when i hit the brakes my car kept going like i was about to hit the person in front of me...im like WTF???? so i put my car in neutral and the idle hops from 1k to almost 3k! NO CHECK ENGINE COMES ON! then i freak out and pull over to a gas station and pop the hood....i dont see ne vacuum leaks? and this is the frist time its happened.....then when i hop back in the car the CHECK ENGINE LIGHT IS ON and the VSA (!) light also.????? whats going on.....in order for me to stop correctly i have to put the car in neutral...or else it'll jump in d5 pretty dangerous......im hoping it goes away when i turn on my car later on...if not what do u think it is?? all i have is a INTAKE
Sounds exactly like what happened to mine. Was something called a "IACV valve". Don't know what it is or what it does, but they were able to fix it the same day. Hope this helps.
I had that exact same thing happen to me... almost like you're sitting there revving the engine by punching at the accelerator. My dealer said it was the "idle air intake sensor" and replaced it under warranty. By the way, the check engine light finally came on after it did this for like an hour or so.
Originally Posted by Brian_C6
Junk!
sounds like the idle air sensor
it is probably your IAC (Idle Air Control). We had that same exact thing happen to my sister's 00' Accord V6. My brother (Mechanic) just bought a new and change it out. It was a pretty simple job. But yeah, chances are it is that.
My car is having a similar problem. I was in a car wash, and when the wash was done, I put it in D5, and the car didn't move. I sat there and put a little gas down, and all it did was rev like it was in neutral. I then put it back in Park, tried putting it in Sequential, but still nothing. It finally went into Drive, but about 50 feet later, while I was in Drive going about 20 MPH, it went back into what seemed like Neutral, because I had it in D5, but the engine was just reving and not giving any power to the tranny like in Neutral. Any suggestions or similar experiences? I have it in a tranny shop, because that seems like a transmission problem. Could it be this idle mechanism that everyone is talking about. Thanks.
Mike Bertram
09-10-2015 09:27 AM
