HELP! Missing hose on my 99 tl
my 99 tl has been over heating and i noticed that it looks like there is something missing here...can some one tell me what this missing part is
![](http://s1070.photobucket.com/albums/u485/vonte614/?action=view¤t=P4210488.jpg)
Vonte614 (04-21-2012)
aww ok...well i checked my oil it didnt seem milky or anything but my radiator cap was melted. and i have plenty of coolant in the car but i don't think its getting to the engine...and my fans turn on so i don't think the thermostat...any ideas on what could be causing the over heat?
Check the hoses as the car is running. You should feel flow going thru them. It might help to blast your heat. Wear some gloves may get hot. Check all the hoses for flow you'll be able to tell with a squeeze. That's a good start. Check the main in and out of the radiator and all others you see.
these two hoses have no pressure while the car is running and there is a lot of white stuff under the radiator cap and all through the radiator...could i just get it flushed or do i need a whole new radiator
http://s1070.photobucket.com/albums/...rent=hoses.jpg
S E L L
dainmezron
10-16-2015 06:56 PM
