help? hyper ground system
hello. i just received my hyperground cables, and i am excited to install them, does anyone have any pointers or diagrams of exactly where they go, or any other use pieces of info? thanks in advance
Veritas vos Liberabit
superballs: i know this is totally off your topic but what offset are your wheels? i think i sent you a pm before, can't remember but i was looking at those wheels in hyperblack and wheelmax.com said they don't even make them in +45 or higher, only +35... wondering if you could help me out, thanks!
What are 'hyperground cables' and what do they do?
.....I guess they didn't come with instructions ? Weird. I've done spark plug cables in the past with other cars, but I'm a little sketchy on this one. Anyone dyno these things or notice any differences ?
no. no help. i havent tried installing them yet. but it should be easy. i was just looking for anyone who has installed them to see if there were any pointers or any help at all
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
also sun auto has a website! there are a few prime areas that the cables should connect. one is from the engine block, and the battery to main ground of the car. my cars in the body shop otherwise i would show you how i did mine based on what i read off the box they came in!
there are 2 ground points on our cars on either side of the chassis looking into the engine bay, and on the front of the car above the coolant resevoir. find a minimum of 5 points all begining from the negative batt terminal. run 1) cable from the cylinder head to neg batt terminal. then from same 1) connection at cylinder head connect a cable to the tranny or cylinder block. then from the same 1) cylinder head connection, run another cable around the back of the eng block, and connect that cable to the intake manifold or surge tank. from that manifold ground spot run a cable to the chassis ground on the left/pass side of eng bay it's right in the vicinity where the cruise control solenoid is on our cars. the last and shortest of the cables goes from the neg batt terminal to the chassis ground located closest to the battery. ( coolant res area, or on inside of fender ) hope that helps!
![Cool](https://acurazine.com/forums/images/smilies/cool.gif)
rcs86
08-02-2016 06:52 PM
SinCityTLX
20
10-19-2015 11:23 AM
ripit
09-26-2015 06:19 PM
maharajamd
Console & Computer Gaming
09-24-2015 03:31 PM
