Help. Hid's on fog lights.
Hi.
I am thinking about installing a hid setup on my fog lights and I was wondering if anyone has done this before.
If so, where did you mount ballasts and with what? drilled screw or something? Is there enough space for the ballasts when I remove the front bumper?
thanks.
thanks.
Well.. if you had tried a search you would have found something. But I think the following link is a good start.
https://acurazine.com/forums/showthr...hlight=ballast
I still think that we should have a DIY section just for the 2nd Gen TL, even if it's just a sticky with a whole bunch of links. But that's only my
You can pretty mount it anywhere you want. There's no right or wrong place for mounting. But as with any other electronics, keep it away from water etc. There should be plenty of space behind the bumper.
