help everytime it rains my car starts to rev up and down
i need some help it rained pretty hard last night and my car started to rev up and down in neutreal and park i went home checked the aem v2 cone and it was kinda wet so i took it of and today i put it back on and its reving from 1 to 2500 i think it may have sucked a bit of water but it still starts and drives is there anything i can do to fix this this happened last night also but it went away i left the car on start and ripped it down my street a couple of times but this time its not going away oh and the engine light i had for a bad o2 sensor flashed 2 times if that helps
thanks in advance
thanks in advance
you may have a bad O2 sensor if that was a known prob before
ripping down the street with an unknown problem not really the best plan~
Wet filter could have allowed some water in- not enough to hydrolock the motor (lucky you!) but enough to get some mixed in the fuel and contaminate the IAC-- on the bottem of TB assembly
I would pull the TB (needs new gasket) and flip over- remove round cover plate and clean disc under it- thats the idle air control valve
Unplug the IACV harness and apply some dielectric grease in the connector.
ahh inspect for problem before ripping apart--good call Kris~
