Help with evap code p0450
Old Aug 28, 2014 | 07:04 AM
AnthraciteTypeS's Avatar
6mt swapped..smart
Anyone successfully cure this code? I'm not sure what to start replacing. 03 cls 6mt swapped
Old Aug 28, 2014 | 06:38 PM
ErickUa5's Avatar
Mr.Helpful Diagram
Thats for the Fuel Tank Pressure Sensor. look for broken rubber hoses or corroded wire connections. Its under the car front of the fuel tank area.
Old Aug 28, 2014 | 07:02 PM
mugenspire's Avatar
3 pedals in my 99 TL
had this same problem with mine during the swap. did you rewire/repin the harness completely when you did the swap? and did it just start throwing this code? when i had that code and had to fix mine, i had to repin and solder the wires from the old harness (99TLP) into the new harness on the body (03CLS6)
Old Aug 29, 2014 | 07:45 AM
6mt swapped..smart
Thanks for the replies.
I saw that post in your swap thread. I'm not sure I would have to repin though as I already have a 03 cls car, just originally auto. It was some wires by the drivers side fuse box right that you needed to repin right?
I'm not really sure when it started but I need it fixed for emissions!
Old Aug 29, 2014 | 01:08 PM
mugenspire's Avatar
yea, the wiring on the auto's and manual's is a different setup though in certain areas of the vehicle(not sure how different from 03cls to 03cls6; but an electrical diagram will tell you). but there were four wires by the driver side fuse box (lt grn, grn, blu, blk i believe). but I'd check the wires around there to make sure none of them are corroded, make sure the connections are tight and if anything you might have to replace the sensor if its bad that would make it throw that code?
Hope you figure it out!
Jamus22
Jun 11, 2023 10:08 AM
samson_420
Oct 8, 2015 01:47 AM
Skirmich
Oct 1, 2015 12:59 PM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
