Help: Engine Cleaning
Old Apr 26, 2010 | 11:29 AM
  #41
01tl4tl's Avatar
if you are good at reading the DIY- have tools and know how to use them- its 1.5 hours at a casual pace
Any job this important is worth doing right or suffer from poor job
egr ports are always in action and cause probs too- wikipedia for system info
DIY should always be the highest quality standard-- in my opine
my work should exceed dealer spec for sure~
Old Apr 26, 2010 | 11:32 AM
  #42
01tl4tl's Avatar
it looks daunting to see the intakes exposed like that in the pics- buts its really no big deal
its just bolts and metal- you clean the metal and rinse- get the rinse water OUT and DRY fully so no water is left in the manifold
if you want better mileage and live where its hot- install a p2r or outlaw engineering manifold spacer/heat insulator while its apart--search for them here or look in sponsored sales threads
Old Apr 26, 2010 | 11:35 AM
  #43
01tl4tl's Avatar
lube the throttle/cruise cables and throttle return springs since they are sitting there and will appreciate it
harbor frieght has a cool `cable lube tool` for motorcycles- works perf on the TL- $3, clamps around cable housing and has place for lube straw- goes right in!
Old Apr 26, 2010 | 07:02 PM
  #44
kriz2fer's Avatar
Originally Posted by fsttyms1
You NEED to remove it to properly clean it. Spraying cleaner into it isnt going to help. Its just a matter of a few bolts and unhook a few things and it comes right off. It takes all of 5 min to take off. Do it properly.
yeah im gonna take it off to fully clean it out...Should i un- bolt the throttle body to make it easy?
Old Apr 26, 2010 | 07:32 PM
  #45
01tl4tl's Avatar
remove the entire manifold and TB together as one unit- its easier than trying to get the bottem corner bolt on TB
The acura method in the diy doesnt remove TB from engine bay because they are not going to work on it, just manifold for single port egr on 99s for a recall- fast is what their goal was
seperate them on the workbench where its easier-
TB may be stuck on, get gasket remover/softner and spray thru edges, wait
You will flip TB over and remove the round cover- clean disc inside- thats idle control valve IACV
also clean the big round plate inside TB throat- both sides and edges- toothbrush and carb cleaner as needed
Old Apr 26, 2010 | 08:17 PM
  #46
fsttyms1's Avatar
If you take off the TB you need to buy a new TB gasket. The other Intake manifold gaskets can be reused.
Old Apr 27, 2010 | 03:29 AM
  #47
01tl4tl's Avatar
good call Kris-
Im used to people installing the thermoblock kit at the same time and it has all the gaskets included to install its spacers
Old Apr 27, 2010 | 03:30 AM
  #48
01tl4tl's Avatar
the only way to properly clean the manifold will require removal of TB from it so you can twist and shake it out-
you clean and rinse thru the throat of the manifold- where the TB attaches~
Old Apr 27, 2010 | 11:15 PM
  #49
kriz2fer's Avatar
Ok just finished clean the egr ports, took of the manifold was no that hard and even poilshed it while it was off...lol
Old Mar 8, 2011 | 12:12 PM
  #50
texholdem's Avatar
Hi Kriz,
what torque did you apply on the 10mm bolts when re-attaching the manifold cover plate? Thanks!
Old Mar 8, 2011 | 03:39 PM
  #51
01tl4tl's Avatar
10 ft pounds on the plastic cover,,thats just snugged so it doesnt come off
the real mainfold bolts hidden under the oil you saw on other thread- are 16
go back thru this thread for detail specs
Old Jul 11, 2011 | 11:02 AM
  #52
justaparadox's Avatar
Exhaust recirc cover on top of intake manifold
I finally got around to cleaning out the EGR ports and saw this messy goodness. These are the channels in the IM cover where some of the exhaust is routed to the EGR valve, upstream of the main port. Some of the channels are totally blocked, which, understandably, gives you the P0401 (EGR insufficient flow). The main port in the intake manifold itself wasn't blocked very much, but I cleaned it out anyways. The 6 little ports in the intake manifold upstream of these channels were almost all the way blocked. Got that junk cleaned too.
Here it is midway through clearing out the solid junk
Oh yeah, I broke one of the bolts that hold down the IM. What is it with torque wrenches that are set BELOW what it it's supposed to be but still breaks the bolts? I was pissed. I ended up using one of the bolts that attached the TB to the IM, then using a replacement bolt from an auto parts store for the TB.
I ended up leaving the throttle cables on the TB when I disconnected it from the IM and just let it sit in the engine compartment, while I cleaned out the IM. Why is it a total pain to get the old gasket off? While I carefully scraped away the old gasket with an x-acto knife I wondered if there was a chemical way to dissolve it.
This project took me 6 hours to do, but I was very very slow and methodical. And there were no problems at start up.
11 years and 151K miles of yuck all gone!
Old Jul 11, 2011 | 01:02 PM
  #53
fsttyms1's Avatar
^ sounds like the TQ wrench isnt calibrated correctly if its set properly and you snapped a bolt ??
Old Jul 11, 2011 | 04:39 PM
  #54
Set at 10 ft. lb. when the instructions said to torque at 16, I wanted to slowly ramp up to the recommended torque...just bought it from Auto Zone.
Old Jul 11, 2011 | 05:03 PM
  #55
Karanx7's Avatar
Unregistered Member
It could have been the shitty torque wrench from AutoZone, or it could have been you. Do you know how to use it properly?
You should have been able to tell that you were going way past 10 foot pounds.
Old Jul 12, 2011 | 09:37 AM
  #56
I started thinking more about it, and I believe the bolt may have been partially yielded from being overtorqued by someone else before. Because I know how much I was putting into it and it was below what I was putting into the other bolts. I was just lucky that thing didn't break all the way and leave a piece.
Old Jun 17, 2014 | 09:29 AM
  #57
TestDrive2014's Avatar
Been trying to follow the DIY EGR Port cleaning (for my '01 TL) but haven't seen anyone comment on draining coolant. Do you need to drain the coolant before proceeding as you mentioned above? Also, relieving the fuel pressure is done by taking off the gas cap and slowly loosening the fuel pulsation damper one complete turn, right?
Thanks for all your help!
Old Jun 17, 2014 | 10:05 AM
  #58
Nicks2001tl's Avatar
There is a DIY here for draining coolant. There is a plug at the bottom of the radiator that you unscrew to drain the fluid.
The egr ports and the coolant flush and relieving the fuel pressure are all separate jobs and doesn`t have to be done in any particular order.
But if your egr port is caked like the pic above then just assume that the egr valve, IACV valve and throttle body have similar issues. Very easy and inexpensive to clean.
Old Jun 17, 2014 | 06:03 PM
  #59
3.2TLc's Avatar
Yeah, basically just grunge work cleaning out all the old residual shit that accumulates.
Just what is your list of things ya wanna do ?.....just tackle one thing at a time and see how things work out.
Old Jun 18, 2014 | 09:42 AM
  #60
I am going to clean the EGR ports and Throttle Body and IAC valve. I have directions from the Helms and Chilton's manuals and both as I recall list relieving the fuel pressure and draining coolant as part of the steps before removing the Upper Intake Manifold. If I don't need to drain the coolant when cleaning the EGR ports, its one less thing to have on the ground/get in the way/me to potentially screw up at a time should something not work when I put the manifold back together after cleaning the EGR ports.
Old Jun 18, 2014 | 09:46 AM
  #61
Is the DIY for draining coolant that you're referring to, the one for the radiator removal where the guy upgrades his (and his pics no longer appear)? Any tips for accessing the drain plug that just needs loosened (I'd like to avoid putting the car on jack stands just for that little thing!).
Thanks in advance.
oyayjoe
Jan 1, 2019 10:17 PM
01CLOwner
Oct 9, 2015 01:07 PM
sockr1
Oct 1, 2015 01:31 AM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
Sep 14, 2015 10:09 PM
