HELP, broken stud on front axle!!!
B93P TL Owner
I broke a stud on my front axle. Does anyone have a DIY on how to replace this? It looks like this car requires you to remove the axle, hopefully this is not the case. Thanks!
all you have to do is remove teh caliper and rotor. then press/pound out the old. then insert the new one and use a lugnut to draw it tight. then just reassemble every thing
Dragging knees in
Then again, I didn't try, so I don't know for sure. It just didn't like you could pull out the stud without taking the assembly off.
Originally Posted by Pure Adrenaline
It didn't look like there was enough room to get the stud out without taking off the spindle to which the studs are mounted.
Well, I guess he's about to find out.
B93P TL Owner
thanks!
Well I must say that I probably made this a bit more challenging for myself than I needed to. I originally attempted popping the stud out by rotating the wheel to align thebroken stud to the left side of the brake/rotor shield (#16 on diagram). Thought I would have enough clearance to drive it out, but to no avail. I thought about grabbing my dremel tool to cut the bolt in half (which would give me enough clearance to pop it out through the side of the shield), but realized that I would still have problems when popping in the new stud. So finally i took kris' advice and loosened the nut so that i could just go ahead and remove the plate. Probably would have been faster to do this in the first place, but lessons learned for me. Thank you both for your assistance!
