help armrest or center console keeps sqeauking
hey guys my car the armrest/console keeps squeaking the first comparment when i left it up its a bit lose is there a bolt or something i can tight? so it stops and also where my seat belt is there is also a little noise anyone ever had these problems?
the lumbar support adjustment on the side of the driver seat- its activator arm pushes against the edge of the center console and instant noise!
check that first
Driver seatbelt mechanism are known to get slow or no retraction of the belt and is a `special covered warranty` item to 10 year 150k miles
Tip to all- leave the center console rear air vent OPEN all the time so air gets out of the plastic tube- or moisture can build there and mold can grow
Also when using cold or hot, it will take that temp thru to the console and your CD or drink cup in the holder can be affected
Leaving the vent open will help overall
When closed there is no escape for the air!
check that first
mlody
12-04-2019 02:11 PM
InFaMouSLink
10-27-2015 06:52 PM
