Help! Adding Addresses to Personal Addresses
Old Oct 18, 2001 | 02:33 PM
tea elle
Guest
Posts: n/a
Question Help! Adding Addresses to Personal Addresses
Can somebody explain to me the best, quickest way to enter addresses into my PIN area? I'm struggling with figuring out how to do it.
1. When I enter my PIN, the screen doesn't seem to be very intuitive.
2. If I've already programmed an address into the Navi, I don't see how I can save it into my personal addresses area.
Thanks for the help guys
Old Oct 18, 2001 | 02:43 PM
edgalang's Avatar
Purchased: April 28, 2001
You have to go the setup screen first. then it asks you which user (driver 1 or driver 2) you want to add adresses to, then you enter in your pin. once in that screen you tap on NEW ADDRESS and you can enter in away. I must have 50 or so personal adresses stored in the pin area, so I guess its safe to say I tend to use it alot.
Old Oct 18, 2001 | 02:56 PM
thephantom's Avatar
The great part about this is if your destination is not on the DVD you can save your current location and add that to your personal address and the NAV will take you there everytime.
Old Oct 18, 2001 | 06:24 PM
tdoh's Avatar
Not necessarily true--I had to save a custom location because the street that it is on isn't currently mapped, and therefore is not addressable on the navi. However, some of the surrounding streets do exist but appear to be mapped incorrectly; after saving the custom location I noticed that it shows up on one of these incorrectly mapped streets, although it seems that the location itself is where it should be position-wise. When I programmed the navi to take me there, it was able to plot a course to said location. But, when I got close to my destination (within 1/4 mile) the navi couldn't provide me with the correct directions due to the fact that the street I needed to go to didn't exist on the map, and the ones in the area that did were layed out incorrectly.
Good thing I already knew what streets to take; in any case, the navi can probably get you to where you want to go. However, program a location in an uncharted area and YMMV...
Tony
08KBP_VA
Oct 22, 2019 01:55 PM
RLX-Sport Hybrid
3G RLX (2013+)
27
Dec 7, 2018 12:11 PM
dainmezron
Oct 16, 2015 06:56 PM
Froid
Sep 27, 2015 06:16 PM
TL14
Sep 24, 2015 04:37 PM
