Help!!!!
Old Jan 3, 2009 | 10:29 AM
goldendragon576's Avatar
TL-S driver
Help!!!!
Everyone said the HID bulb was the easiest DIY, i got the bulb out no problem but now I can't get get the bulb back in and I can't get the spring locked. I can't even get the piece back in WITHOUT a bulb. What am I doing wrong? HELP!!!! There are DIY for taking it out, I realized there are none for putting it back in.
Old Jan 3, 2009 | 11:20 AM
Rajca's Avatar
wham bam thank you ma'am
move the spring back, insert bulb in hole and align, put the spring over the base of teh bulb and then the longest part of teh spring hooks onto a clip on teh headlight housing. then plug the bulb in adn but the cover on. the fist time is a bitch (brian knows what im talking about) if u take the whole headlight housing out and look at how it goes in its a piece of cake. just takes time and patience, working in a tight spot doesnt help either.
Old Jan 3, 2009 | 11:21 AM
TL-S driver
Ok, FINALLY got the bulb into place, apparently when I was trying to take it off I bent the right side of the spring and kept getting tucked under the side.
