Help!!!
Old Apr 5, 2003 | 12:28 PM
TouringLuxury99's Avatar
Help!!!
Ok guys, My tail light is broken, or something. When my lights are on, the driver side tail light is messed up, only one bulb lights up. The brake lights work fine, I think. There should be 2 different lights in the same bulb, or atleast that's how it was on my Jeep anyways. What should I do? How do I go about taking the light off, a getting a new bulb, if that's what I have to do?
Many thanks again,
-Paul-
Old Apr 5, 2003 | 12:53 PM
-Rz-UA5's Avatar
just replace the dead bulb.
the brake bulb got 2 fuse in it. 1 of them probably burn out.
Old Apr 5, 2003 | 01:06 PM
BradNH's Avatar
The lamp type is T20. I'm guessing you have ~50K miles on the car? I had two go out on my 99. It is very easy to replace if you follow the drivers manual.
P.S. these are japanese bulbs that stink. My suggestion is to replace all 4 at once.
Old Apr 5, 2003 | 03:42 PM
What would you suggest I replace them with?? And I should check the manual about taking the light off? That should fix it??
-Paul-
Old Apr 5, 2003 | 04:08 PM
JayDawgs2000TL's Avatar
From: Allover, but home is in Indiana and Wisconsin...
just open the trunk and pull back the carpet behind the light... they are just twist and turn sockets for the lights so they are easy to come out.... I went to auto zone and they grabbed the right replacement lights for me and they took a minute to put in.. it's not hard at all...
