Help!!!
Old Dec 6, 2001 | 07:46 PM
rayman009's Avatar
Just too cool
Help!!!
I'm planning to debagde the acura lettering and the 3.2 tl on the back. I'm not real sure how I do it. Do i use a flat screw driver and slowly work it off?
If i get mufflers, do i have to do any welding? or is only for univeral mufflers? Do they make mufflers for TL's?
If i was to get neon lighting in my car. How do I plug them in? Do i have to get a thing to connect all of them?
Old Dec 6, 2001 | 07:54 PM
badazzTL's Avatar
Peach Tea
Re: Help!!!
for the debadging, just use dental floss and work it off. takes like 3 minutes. don't forget to wax after you peel all of the goo off. DONT USE A SCREWDRIVER!!!
don't know about mufflers, i would like to know also
i had neon lights, i had them hooked up to the ciggerette lighter. i would recommend hooking them to your lights or something. i took mine out cuz all the wires got on my nerves:o
good luck
Edub-TL's Avatar
Sticky Rice OwnZ joO
DO NOT REPEAT, DO NOT use a screwdriver!!
You can use a hair dryer to heat up the adhesive and then use a credit card or dental floss to work off the badge..
Yes there are muffulers(Exhausts) for our TL.. there are a few choices.. Comptech is probably the most popular, followed by HKS.. both are AxelBack exhausts..
Click here for all the exhaust available for the TL
http://www.acura-tl.com/search/resul...pageid=exhaust
sorry, don't know about the neon lighting..
Old Dec 6, 2001 | 07:55 PM
SL1200MK4's Avatar
yet... like what Edub said...
heat it up, and don't force it... don't use screw driver... that will screw up your car...
Comptech I think you can just bolt on...
Old Dec 6, 2001 | 08:07 PM
StanMan's Avatar
fishing line works too...although stronger, it's actualy thinner and less tactile so the shave might be cleaner.
