Heat problem
Old Feb 20, 2008 | 01:08 PM
Stranjtrax's Avatar
3rd Gear
Heat problem
I have an'03 TL-Type S and as of this week my heat is taking longer than usual to crank up. I turn the fan on and cold air comes out, even after I've been driving for more than ten minutes. And when it does come out, it's not as hot as it usually is. The temp gauge is where it should be and antifreeze is fine. What could possibly be the problem?
Old Feb 20, 2008 | 01:10 PM
kushsmoker's Avatar
B A N N E D
It's probably the heater core or hoses connected to it
Old Feb 20, 2008 | 01:29 PM
Stranjtrax's Avatar
3rd Gear
I did a search on the boards and saw where quite a few people had this problem. I am going to try the "pulley quick fix" that seems to have worked for many. Thanks Kush.
Old Feb 20, 2008 | 10:41 PM
kushsmoker's Avatar
B A N N E D
no problem.. tell us how it turns out
Old Feb 21, 2008 | 08:06 AM
3.2TLc's Avatar
My guess is that your thermostat is not fully opening, but you said that the temp gauge is reading normal..........does it take longer to get to that point ? If so, maybe the t-stat is sticking. Make sure that the coolant ratio / level is not low and that there's no air within the cooling system. Another thing may be possibly a faulty coolant valve which is mounted on engine side of the firewall. One last culprit could be the temp sensor for the automatic temperature controlling used in our TL's hvac system. Good luck, try the simple stuff first !
Old Feb 21, 2008 | 09:14 AM
phee's Avatar
I got the Shifts
link to that pully quick trick please!
SidhuSaaB
May 30, 2020 12:40 AM
LoneRonin
Jan 4, 2016 01:03 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
