HEADLIGHTS, need help
Ok. it looks like there was a small condensation in my headlights (not sure why) its dry now but it left "haze" inside the casing and on the silver coating...
Is there a way to fix it somehow without taking apart the whole headlight?
Do you know?
Do you know?
Originally Posted by Mr
If you cleared your lights and got condensation. It will only come back and even blow your balastic or bulb next time it rains... You would have to reopen the headlights and reseal it...
Mr.
The headlights are "stock" and still got condensation...
I think this will be the reason to open and reseal
To bad I cant take out that ugly red plastic thinkg couse in both headlights the silver coating thetre is covered in small bubles like dots...
Have no idea why it happened only there and why it happened?Do you think its possible to repaint only that small part?
What spray pait I should use so it would look the same as other silver coating?
How do you know its covered if you have taken out the reflector.. It might just be a reflection from the back of the reflector.. I dont think it would look good if you just painted over the small portion. It would look out of place because the entine casing is reflective.
If you paint it use high temp paint...
Hope that helps...
Hope that helps...
AmplifiedDetails
Sep 24, 2015 02:55 PM
