headlights both shut off while driving
Old Aug 29, 2016 | 02:36 AM
1999acuratl3.2's Avatar
3rd Gear
my headlights both go out while driving and won't come back on until I click the brights and then shut the brights off and they work until they shut off again.. Could use some help or a wiring diagram thank you..
Old Aug 29, 2016 | 08:33 AM
myron's Avatar
it's most probably your ballasts, I had the same issue and I had to turn them off and back on and they worked for a bit but it would go out again. I got an aftermarket HID wiring harness hooked up and fixed the problem pretty easily.
Old Aug 29, 2016 | 10:10 AM
ErickUa5's Avatar
Mr.Helpful Diagram
Yea you might as well go aftermarket on that, considering you have a 99 those ballast lasted a while.
Do not buy a used kit or salvage yard replacement.
Old Aug 29, 2016 | 02:57 PM
3rd Gear
thank you
im not big on just guessing whats wrong so can anyone give me a wiring diagram so can be sure to chase my problem down i only wanttot fix it once. not change the ballasts and then still have the same problem and find out its my combo switch or ignition.. thank you
Old Aug 29, 2016 | 03:08 PM
3rd Gear
thank you
May 20, 2026 01:55 PM
00TL-P3.2
Feb 11, 2019 11:23 AM
Modassir
Nov 17, 2016 12:20 AM
TheChamp531
Jun 22, 2016 09:45 AM
