headlights
Old Oct 2, 2009 | 12:20 AM
pillsbury8's Avatar
headlights
right one goes out when i drive. and when i find out it goes off, i turn it on and off and it turns back on, and then goes out again. new bulbs im assuming? anyone got any suggestions?
Old Oct 2, 2009 | 05:11 AM
01tl4tl's Avatar
swap the bulbs left to right and make sure its not a ballast issue
Then see the many threads on bulb choices- 4300k was stock color
5000 a bit more blue, 6000 way more blue but less white on the road
5000k good choice- Kaixen a good brand
Old Oct 2, 2009 | 05:12 AM
01tl4tl's Avatar
In general the gen2s are ready for bulbs by now with average useage
Old Oct 2, 2009 | 08:42 AM
NSXNEXT's Avatar
I had the same problem and swapped them and haven't had an issue since (140,000 miles on original bulbs).
Maybe the bulb is a little loose?
Old Oct 3, 2009 | 05:36 AM
TheMegalodon's Avatar
I'm a thrill seeker in my
I'm having the same damn problem. I bought a new OEM ballast off ebay, replaced it today and found out it's the bloody bulb that's flickering off. So pissed. It's embarrassing to have you light flicker like all hell and then go out on a turn.
Old Oct 3, 2009 | 09:52 AM
'03TL-S's Avatar
Should have swapped the bulbs to see if it occurs with the bulb from the other side. Test out the cheapest part first, which is the bulb, so you won't be replacing an expensive part that need not be replaced.
Old Oct 3, 2009 | 02:42 PM
It's all good, I used my tax return to pay the ballast. Since I replaced the driver's side in spring I figured it would be good to replace the other side sooner rather than later. When I removed the passenger side it was working but looked quite rusty and spent.
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
