headlight out
Old Dec 13, 2009 | 08:00 PM
taintedplay's Avatar
headlight out
ok, so water got into my drivers headlight, and a bulb burned out. it was the normal light one, not the brights or turnsignal or anything, not sure on the name of it. Looking on sylvania, is the the low beam or high beam headlight? and would this: https://acurazine.com/forums/sponsored-sales-group-buys-10/hid-special-%2460-shipped-acurazine-members-723872/ be something i coudl get to fix that?
Old Dec 13, 2009 | 08:21 PM
TLin401's Avatar
'13 Hyundai Sonata
No you just need D2S or D2R bulbs.
Try ebay for them.
Replace in pairs.
You would have more trouble trying to figure out how to wire the aftermarket ballasts up to the factory ballasts and all that BS that you do not need to go through.
Old Dec 13, 2009 | 08:30 PM
well that sells new ballasts along with new bulbs for only 60 bucks. also my factory ballast might be out. so i would like to replace all of it.
Old Dec 13, 2009 | 08:31 PM
TLin401's Avatar
'13 Hyundai Sonata
Well I wouldn't go aftermarket
Even though the OEM ballasts are $$$ I would still get them and replace them.
Old Dec 13, 2009 | 09:03 PM
may i ask why?
Old Dec 13, 2009 | 09:42 PM
TLin401's Avatar
'13 Hyundai Sonata
The OEM ballasts are meant to last for a long time. Some last up to 10+ years and if you get aftermarket ballasts then you do not know if they are assured to last.
You can go aftermarket with the ballasts but it would be harder to wire.
There is no straight bulb number that the ballast would hook up to. The wires that go into the OEM ballast are different than those that go into an aftermarket ballast so it would not be a direct fit.
It can work but it will take time and knowledge. You can splice it and cut the wires to work but IMO it is more of a headache than needed.
Old Dec 13, 2009 | 09:56 PM
if i did go aftermarket, would a d2r bulb be the one to use? not a 9000something number?
Old Dec 13, 2009 | 10:01 PM
TLin401's Avatar
'13 Hyundai Sonata
Yes that would be the bulb number.
Old Dec 14, 2009 | 12:18 AM
01tl4tl's Avatar
moisture in the housing drips down and out the wiring hole on bottem- directly onto the ballast- killing it
must fix seal on headlight or replace housing with new to cure the prob- or you will blow bulbs and ballst over and over
try junkyards for ballast
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
