head light gos out after a few min
hello every body ok so 2 day my right head light gos out after a while but it well come right back on if i turn off and turn it back on i look at the switch and it has like a brown oil on it i tryed 2 clean it off but it seem 2 come back but can any one tell me if it the light or the ballasts that is mess up or whats going on ?
there is a lot of this going around, me included
Most are replacing the bulbs ballast and ignitor wire from a full kit like hidextra.com has for us
cheaper than any 1 part from acura!
an acura tech on here suggest the silver metal thing mounted on back of housings is a controller and fails= causing our problem
it comes with the new full kit in a different- and `waterproof` form
If there is moisture inside the headlight housing lens- must fix that first
but def points to moisture damaged parts issue
if you have swapped the bulbs left to right to see if prob follows bulb
Or have seen a pink or purple tint at startup of bulb (dead bulb)
that narrows the diagnostics
with the age of our cars and ~certain parts~ not being waterproof- the ballast and the control module seem to be dieing off at an alarming rate
good thing hidextra and ddmtuning offer such unreal low price `kits`
for 50-60 bucks!!, I dont care if it last 2 years or 10 --I will be happy
cycdaniel
12-17-2019 10:58 AM
RLX-Sport Hybrid
3G RLX (2013+)
43
12-16-2015 10:45 PM
HeloDown
09-08-2015 06:51 PM
