HCHHON or CHIEN . . . need help putting back wood trims?
hey i need help installing back my wood trims . . .i took them off to paint them and i try using double stick tape but the trims still pop off easily or it would pop out when i slam the door . . . what did you guys use? expoy? . . . help me out guys
Received 1,080 Likes
Explain how you removed the trim and I can give you some suggestions on how to put it back.
I cut the plastic rivet head off of each post that holds it to the door. When you cut them off you'll see that they are hollow.
I then bought some small screws and washers and screwed it back on to the door.
i had to drill em out . .. it was a pain in the a** . . . hehehhe i tried double stick tape but they dont work for nothin . . . hahah they stayed on better when i didnt use anything . . hahah
cycdaniel
12-17-2019 10:58 AM
dre707
09-08-2015 08:32 PM
