Having issues with the gearshift getting stuck in park
Old Nov 12, 2018 | 01:34 PM
TL260power's Avatar
I am recently experiencing problems with the gearshift getting stuck in Park. No matter how hard I press the brake pedal it just won't budge. Until finally with many attempts of pressing the brake pedal it moves. Other times when I first get in the car it works with no issues at all. Any ideas on how to fix this?
Old Nov 13, 2018 | 06:43 PM
Saudade's Avatar
USAF Veteran
Veteran: Air Force
You likely have an issue with the interlock. There is a latch that prevents the shifter from changing out of park unless the brake is pressed. Look on the bezel around the shifter, you'll see a small cover. Pop the cover out and you can stick a thin stick (like a pen refill or bamboo skewer) and manually disengage the lock. If that works, then you have an issue with the interlock and not some other linkage.
Old Nov 13, 2018 | 07:13 PM
TL260power's Avatar
Yes, manually disengages works.
But I noticed that my brake lights do not light up when I press on the brake pedal and that's when I have issues with the gearshift. And when they actually do light up, I can easily shift into drive.
So the brake lights do not engage when I press on the brake pedal.
At first, I had to press hard on the brake pedal for the gearshift to work, now that's not working anymore. So now I have to manually disengage the lock.
I read that it can the a fuse blown out or maybe event the bulbs. But then that would mean all three bulbs burned out which I don't think is the issue. I think wiring or a blown fuse..
Old Nov 14, 2018 | 09:30 AM
Saudade's Avatar
USAF Veteran
Veteran: Air Force
Then check your brake light switch.
PeterUbers
Apr 6, 2004 03:13 PM
ucla107
Mar 1, 2004 08:53 AM
TL-S Man
Jan 14, 2002 06:16 AM
Aug 7, 2001 02:10 PM
