Have Radio Code...can't enter it!
Old Aug 13, 2007 | 06:23 PM
Buzz Smith's Avatar
Hi...(searched the forum...couldn't locate an exact problem/answer)
'99 3.2 TL 165,000 miles
Just got the car back from the body shop and the radio was inoperable awaiting it's code.
I found the sticker with the 5 digit code and I swear entered it correctly...hear a beep and now the display says COdE E. No radio, etc.
I turned the car off and waited about 10 minutes.
Radio display still says COdE E, and it will not allow me to enter any numbers.
I only tried once prior to the current display, and can't get past this error indicator.
Any ideas?
Thanks!
Buzz
P.S. Nav system is inoperable, too, but not due to code failure...it's been dead for a few months...related?
Old Aug 13, 2007 | 06:51 PM
blueguava's Avatar
Have you tried:
[1] Pulling the fuse and putting it back in. The fuse for the radio is located behind the dash panel on the passenger side. Open the passenger door, remove the plastic dash panel and the fuse you want to pull is the first fuse on the top left corner of the fuse box.
[2] Disconnect the battery (negative first then positive) and then reconnect (positive first then negative). This basically resets everything.
Good luck.
Old Aug 13, 2007 | 11:28 PM
Bob_F's Avatar
Sometimes you need to disconnect the antenna connector at the rear of the radio. I had to do that once on my TL.
Bob
Old Aug 14, 2007 | 07:18 AM
Buzz Smith's Avatar
Thanks for the replies...
Shortly after posting, we got in the car and fo some reason, the COdE E error message was gone and the 5 digit code entered correctly. Who knows?!!
Buzz
Old Aug 14, 2007 | 09:10 AM
Bob_F's Avatar
Buzz
Cool! Thanks for the update.
Bob
Old Aug 14, 2007 | 11:04 AM
CHEWKNOW's Avatar
Yeah..same thing happened to me. I had to disconnect the battery for a few minutes.
Old Aug 14, 2007 | 11:53 AM
Razzi's Avatar
T-Swzy
it worked because it feared the wrath of AZiners
Old Aug 15, 2007 | 08:00 AM
Buzz Smith's Avatar
I hadn't thought of that!
Can the collective AZine wrath now be directed towards my defunct GPS system?!!
Buzz
Old Feb 4, 2008 | 06:57 PM
mzahidi's Avatar
SOS
i got a similar problem to : https://acurazine.com/forums/ramblings-12/xbox-max-payne-help-89271/
head unit keeps on cycling to the code menu
and then when i enter my valid code, the radio blinks err 1, then the next attempt gives me err2...so on so forth till i get the ERRE...
, my fuse had shorted out not kool
i will pop the head unit out and remove the ipod connector and the antenna connector...
Old Feb 4, 2008 | 08:53 PM
takahashi's Avatar
B A N N E D
im suprised no one address this solution yet.
you need to have the antennae cable removed, push in code, then place it back in.
Old Feb 6, 2008 | 12:03 AM
drumminfool's Avatar
drumminfool
same thing happened to me, i accidentally entered it wrong got the same code tried again and it wouldn't let me input, turned off the car waited awhile. still the code shows. then i just parked the thing and went out a few hours later and was able to enter it no problem. i think it might be a security feature that shuts down the radio for like an hour or 2 before it lets you enter the code again.
Old Feb 6, 2008 | 09:11 AM
Bob_F's Avatar
See Post #3.
Old Feb 6, 2008 | 09:30 PM
acitydweller's Avatar
Read post #3 as your suggestion was already mentioned as per post #12.
Read Post #4 as it was solved already.
dirleton
Aug 6, 2024 08:19 PM
Puma Jim
20
Oct 20, 2016 11:59 AM
SinCityTLX
20
Oct 19, 2015 11:23 AM
jdmaszfcuk
Oct 19, 2015 12:31 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
