Has anyone tried the Bosch Platinum IR Fusion plugs?
S E L L
I know that mostly everybody says go with the NGK Iridiums but I'm curious about these Bosch Platinum IR Fusion plugs. Has anybody here tried them out? Did they work better, worse, the same? The main reason I'm considering them is because Bosch seems to make good quality products and they make a good argument. http://www.boschautoparts.com/Produc...s/IrFusion.htm
Not good for our ignition system
If you notice the size of the ground electrodes on the Bosch versus the single super fine wire type of the NGK- you will understand why the approved plugs are the approved and recommeded by ziner plugs for the TL/CL
Small diff on the metals - as long as you bought NGK you are fine
S E L L
Originally Posted by SN_04TL
I got these installed in my tl 6spd. Its more responsive and smoother running, so far so good. No complains; they have about 900 miles on them.
SidhuSaaB
05-30-2020 12:40 AM
ITSJESTER
17
12-06-2018 02:29 AM
Joe Avesyan
09-29-2015 03:57 PM
