Has anyone changed there differential oil?
I am going to change my tranny fluid this week and was also wondering if anyone has changed the differential fluid. If so, where can i find the drain and fill bolts? What gear oil should I use?
Differential- a drivetrain gear assembly connecting two collinear shafts or axles (as those of the rear wheels of an automobile) and permitting one shaft to revolve faster than the other
No differential in a TL- FWD.
There isnt a separate differential on the TL. Its FWD so its all built into the trans. Use Honda ATF or Amsoil ATF. Not a weighted oil.
Yes drain fill is just that Drain 3 quarts drive to mix and heat up, repeat 3 times. Only 3 quarts will come out of our trans at a time (of 7.6)
AZ Member.. :X
argh! Really! i did not know that... I even asked the ACURA dealership if it would hurt the transmission, they said no no no, its fine. And im really good with cars, i should of done it myself... and pay 40 for all the fluid...
I've been checking Ebay hoping to catch one used to save some $ but no luck yet. There's always ones on there for 1st gen & 3rd gen but no 2nd gen- ?
mada51589
05-03-2022 08:54 PM
