For the guys that removed their cat and mid muffler
Im thinking about taking the mid muffler out and also the cat. Did any of you have issues with the check engine light coming on?
I wouldnt remove the cat, just get a high-flow one, i removed the mid mufflers and got an axleback and im happy with it
Ive got the RT cat and gutted the midmuffler, I love how it sounds.
Searchhhhhhhhhhhh this has been talked about a million times. Infact I think theres a recent thread in the performance section...but yea remove mid muffler and replace cat w/highflow cat and it'll sound decent.
i took out mid muffler no codes..
Any thing after an O2 sensor that is removed Will not cause an C.E.L to come on...
Originally Posted by Sal's Type S
(Post 10786318)
I did do some searching on the subject, but didnt notice anyone talking about the check engine light coming on so I was asking just to make sure. Im sure cutting the cats might make it sound even louder. On my Trans Am I didnt have the issue with the check engine light being on when I eliminated the cats...... thanks for the info.
When i got my mid-muffler removed the guys unplugged my O2 sensor, They claimed that any custom work would mess up the car/codes. I crawled under the car and found the o2 sesor unplugged. I just plugged it back in. You might want to check to see if they did that to you.
Originally Posted by Mikey 03 TL Type S
(Post 10793007)
I have a Random Technology high flow cat and no mid muffler and get a bit of rasp around 2500 - 3000 RPM that can get a bit annoying, but I think that the comptech headers add to it and don't think that all TLs will do that. :2cents: |
i got mine removed recently. mid muffler removal has nothing to do with check engine code.
removing cat does. engine is fine. everything is fine. just no signal to oxygen sensor. if you want power and sound and no cat. just drill a hole the size of the oxygen sensor. screw it in. plug it in. and ull get rid of the code. thats what i did after a couple of hours. all good now :) |
Originally Posted by bibledriver
(Post 10800725)
on your TA, the cats were after the 02 sensors likely, as an above post points out. This car has an 02sensor in the cat to ensure that it is remaining compliant to California and/or LEV standards. if the 02 cpu detetcts no difference between values at the 02 sensor in your cat and the 02s prior to it, you will get a CEL and also not pass emissions testing.
Originally Posted by zeppler
(Post 10822296)
get an o2 bung welded in.
</thread> |
