grounding points
grounding points
i searched but didnt find what i was lookin for...
i made my own grounding kit using 4awg wiring and gold plated terminals yesterday... here's what I did:
battery > chassis
battery > tranny
battery > intake manifold
tranny > chassis
intake manifold > alternator
my question is about the last wire... the one that goes from the IM to the alternator... is it possible that it causes engine whine in my stereo?
I played my system before/after connecting that grounding wire and there seemed to be less engine noise when it was not connected... is it possible that the engine reving from the manifold to the alternator makes my system whine??
Would it be better if I grounded the alternator from the chassis?
Also, I have some wiring left, are there other points I can ground that I didnt think of?
-Justin
battery > chassis
battery > tranny
tranny > chassis
-Justin
Originally Posted by fsttyms1
Just a quick question, why to a a aluminum intake? i would run to the chassis.
i read about people grounding the IM so i said why not.. cant be bad to have better engine ground.. i've even seen TBs being grounded...
which points do YOU recommend?
1. the passenger-side inner fenders to..
2. a bracket right behind the power steering pulley to..
3. the front valve cover (in front of the tb)(bellow the pvc pipe) to..
4. the tranny to..
5. the negative battery terminal to..
6. the stock grounding point behind the driver side headlight.
4. the tranny to..
here, this is where i learned bout the "big 3"
good read
http://forum.sounddomain.com/ubb/ult...c;f=5;t=007801
good read
Originally Posted by Rpappi
have any of you noticed a difference in the cars performance. electrical and mechanical when doing this???
just replace the 3 main stock grounds - tranny to chasis and the 2 off the battery. I started a thread a while ago when I did this. Anymore and its just a waste and you will clutter up the engine bay
Originally Posted by phipark
My audio installer removed that last ground wire. He said is was useless. System sounds much better and the buzz I had is gone.
Originally Posted by PenancE
^^ that a voltage stableizer? (sP) yo where can i buy that....
does anyone have pics of their grounding kits??? I know, stupid right? ima noob and dont know how it is suposed to look. and should I make my own or buy it? also, were can you buy them from? Thanks
is there a DIY, i would love to do this sometime in the next couple of weeks.
my dad will freak if he sees me messing w/ electricity so i wanna know what i am doing. (grandfather died of electrocution)
good read
good read
pics of stock ground points?
I have been searching on here for a while and haven't found any pics for where our stock/oem grounding points are so I am bringing this old thread back. I took a quick look under the hood and saw the one from the battery to the point behind the driver's side headlight. Where are the other stock ground points and how many are there? I am thinking about buying the 4 gauge wire and redoing my stock grounds. Also, what are some of the other good non-stock ground points if you want to do that?
To fix alternator noise
These are the ones I did. I can't really say that I noticed a difference, but it was a cheap easy mod to do so I figured why not. I used 4 gauge wire, gold plated wire terminals and Stinger Digital Battery Terminals like the one below. Looks pretty good, nothing special though.
The post you are responding to is almost fourteen years old; I rather doubt your advice, however well intended, helped @snowman81.
The following 2 users liked this post by Ron A:
ProfessorFunk (01-20-2020),
whitetiger5 (01-20-2020)
whitetiger5 (01-21-2020)
Jamus22
06-11-2023 10:08 AM
emailnatec
29
09-28-2018 04:27 PM
