Green fluid leak from the engine
7th Gear
I have a green fluid leaking seemingly from the interior of the engine.
It is off the same emarald green color as the engine coolant but it is oily (unlike the engine coolant).
The local mechanics didnt seem to have a clue abt it. Can any one tell me what that leak could be ?
Thanks !
Thanks !
2003 SSM TLS
The ONLY thing green is coolant. Keep in mind that coolant flows through your engine to keep it cool. It is probably one of 4 things:
leaking radiator hose at the motor or water pump
leaking head gasket (this could account for oil & coolant mix)
leaking freeze plug (these are brass plugs on your block to keep the block from cracking if your coolant freezes)
leaking water pump where it bolts to the block.
You should be able to trace with a little diagnosis. Could be simple or expensive to fix depending on what you find.
Best of luck on tracing the leak and keep us posted on what you find.
id recomend you find a different mechanic if the one you brought it to didnt have a clue.
it may be a simple fix right now but if you let it go it can/could get really expensive
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
Mike Bertram
09-10-2015 09:27 AM
HeloDown
09-08-2015 06:51 PM
