got the injen cai on today.....
Agean Blue Bishes
1 Post
holy crap this thing is awesome biggest pain in the ass was the coolent line and figuring that out. other wise the thing friggen rocks. in vtec land it sounds pure race car. love it
I am thinking about either the injen or aem,.. Why did you go with the injen.. Also... how long did it take you to install ? why was the colant line a problem ?
sounds like the injen is the system
i
whichever u can find for cheaper, go with. they're both pipes with a filter. some ppl have had problems with AEM bracket that screws to chassis breaking, mine has been good so far.
Purchased: April 28, 2001
Originally Posted by MikePA
What problems did you run into with the coolant line? You're referring to the one that connects to the stock air box, right?
NO!
Coolant line = liquid. It DOES NOT connect to the airbox at all.
And when he meant problem...he proably means spilling coolant all over the place while replacing that line. Either system you go with (AEM or Injen) you'll still have to replace the coolant line.
EDIT:
Ahem...I meant if you want to install the CAI PROPERLY, you'll need to replace the coolant line. Reason for this statement is that I've seen some hack job installs where they use stock lines and just cut them up to fit. Do a search...there's a couple of improperly installed CAIs floating around the board.
Agean Blue Bishes
1 Post
well the coolent line i had was too short so i had to go buy some new stuff. the way the book shows comign from the thermostat then to the throttle body next to the butterfly. the butterfly rubs up against it so i routed it from the front of the engine like the vaccum. its a pain to get to the one set of clips to get the hose off, cut my hand all up. other than that it was easy. took maybe 40 minutes to do it. im a pro at taking the bumper off this is like the 5th time. i'll try to get some pics some day.
@ slide or die @
Originally Posted by edgalang
NO!
THE PROPERLY WAY TO INSTALL a CAI, is by simply bypassing this line. In other words connect one end with the other with a little adapter thingy available in home depot, auto discount, pep boys, autozone, etc... looks like this:
line in --> ===== --::::-- ===== <-- other end
Not neccesary to replace line either...just bypass and its ok. BTW, the Injen cai comes with the bypassing thing...I've got and installed myself...PROPERLY
@ slide or die @
Oh demolition...WHY do you think Injen included that rubber hose?? you take a peace of that and slide it ontop of that other line and the other end on the litthe thing on the CAI
Enjoy, hope my info helps. pm for questions
*btw i can take some pics of my installation so you know what to do. But meanwhile, running with that hose unplugged is fine.
Originally Posted by etxxz
Course it connects to the stock airbox. Stock box has a little radiator inside where a the coolant line comes and and out.
If you read his signature carefully, you'll know that he's talking about a TLS...NOT a TLP. For a TLP your statement is correct...however for a TLS (which is what this thread is initially about) it's NOT.
Again, with a TLS...the coolant line DOES NOT even touch the stock airbox.
um, i just installed my CAI today as well, and i h ave NO idea of what you guys are talking about...
are you talking about the hose that connects UNDER the pipe? and etxx, please post pics. thanks!
Here's a couple of picstures for reference. (2002 TLS)
My restored Injen CAI (black ceramic paint with K&N Xtreme filter)
Air filter is slightly bigger than stock Injen + it has more pleats for better filtration.
Mounted without the filter.
Notice how much higher the filter sits compared to AEM. When replacing the bumper, the filter head lies ABOVE the foglight housing. A properly installed Injen should NOT hit the back of the left foglight clip.
The red hose in the rear is the coolant line.
Here's another angle.
What it used to be originally.
What it used to be before.
Originally Posted by big mike 13
edga... im confused, is this for a TL-S or TL-p?
and if it is a TL-p, does the TL-s have 3 hoses as well?
THat is a TLS.
2 hoses go in the airstream....1 in front, the other in the rear. The 3rd hose you see up front is the coolant line. Which to this date, noone can explain why you'd want to heat up the front airhose.
i hate to sound like a complete moron, but the red tube up front (i think it used to be metal) was also attached to 2 other hoses, correct?
so what happened to them now? is Injen's hose configuration better than AEMs?
though the Higher filter looks much better, where as i lowered m car and my filter is pretty damn close to the ground.
The metal piece is made up of 2 hoses. The big one is air, and the smaller one in the rear is HOT HOT HOT coolant.
EDIT:
I can't comment about AEM nipple placement, but it should be similar.
i
never had to replace any hoses with my AEM. My AEM was easy as hell to install. Pull out stock airbox, stick intake in its place, connect hoses to their specified places. My filter went in fine, its sitting fine in place of the resonator.
if u dont like that the filter sits low, simple solution: cut off some of the piping to place the filter up higher.
Originally Posted by Elementz
EXACTLY. INJEN PROVIDES EVERYTHING YOU NEED TO DO A PROPER INSTALL. USE THE BYPASS COUPLER AND YOU'll BE GOOD TO GO!
You guys must have a newer version. My Injen CAI did not come with a bypass coupler...nor is it even needed.
Boomer SOONER
think of it this way...it has to get wet enough for the engine to suck the water through the air filter. The filter is made to flow air, not water, so for air to get through it, it will have to get VERY wet - aka virtually submerged in water.
Obviously a few splashes will not hurt it - they wouldnt put the filter down behind the bumper if that were the case, because it may get a few "half" splashes on it while driving.
Originally Posted by Dark DJ
wow very informative thread, so im guessin' the TL-S people can't do the 'Puck Mod'? i didnt see a second resonator under b/w the airbox and T/B
Correct. There is no such thing as a 2nd resonator for the TLS.
Agean Blue Bishes
1 Post
yea but i bought mine used and there was no way it was fitting. so instead of running the hose back toward the windshield i ran it similar to how the stock one was run from the front of the car and over the intake. just looked more direct and it wouldn't rub on the butterfly for the intake.
@ slide or die @
i still dont understand what you say about the buterfly...there should be nothing around it exept the throttle body's hole.
Maybe its different on the Tl-S so i woulnt know, take a pic, and e-mail it to me so i can help out better...still, there should be nothing near/around the butterfly
Agean Blue Bishes
1 Post
the part the throttle cable is attached to. to run the line from the back and plug it into the back near the throttle body there is a peice of metal that roatates. its connected to the throttle that opens and closes. the hose rubs up against it. the peice that came with my USED intake almost wore all the way through from it rubbing against this. so i just routed it similarly to the stock set up. no need to worry. i'll take pics maybe tomorrow
@ slide or die @
Wierd, so the line interferes with the throttle cable. That's bad, what if your throttle gets stuck and you crash and burn? (turn ignition off *IF*)
If this is the problem, then you'll just have to rerout, OR get another hose and simply extend the one you have and go under. Better safe than sorry bro.
Comptech Freak
Originally Posted by yunginTL
30 minutes to an hr o 2
or else it's like 1.5 hr
lanechanger
10-13-2015 10:56 AM
