Good tip when replacing front motor mount!
Old Jul 12, 2011 | 07:41 PM
RC99TL's Avatar
I had to replace the radiator fan today when my wife mentioned that the car seemed to be running a little hot on her way home. It's real easy, just remove the battery and clear the electric connector, radiator overflow tube, tank and then the cruise-control cable from their holders and 2 10mm bolts later it lifts right out.
Looking in I'm like: Aw Jeez! The front mount is there with all the fasteners at the ready!
Wish I thought of this as I was snaking extensions in from above and below!
Also makes replacing the lower radiator hose a different experience as well.
One thing I would do is put a piece of cardboard against the radiator to protect the soft aluminum fins from getting damaged while wrenching.
Well I hope this helps as I have not read of this here yet.
180k and still going strong!
Old Jul 12, 2011 | 10:08 PM
Neejay's Avatar
hmm...I'll keep this in mind. Thanks.
Old Jul 12, 2011 | 10:29 PM
ANC297's Avatar
Bonki' Ehrite!
Hmm, thats a pretty good tip, I struggled pretty good doing my front mount.
Old Jul 13, 2011 | 10:23 AM
acutee's Avatar
Nice tip, thanks. Simple enough to give us a good working space.
Old Aug 22, 2011 | 02:02 PM
OregonTL's Avatar
Thanks so much for the tip. I am tackling the front mount, side mount and belt tensioner this weekend on my wife's '02 TL-S
Old Aug 30, 2011 | 02:52 PM
ego_roots's Avatar
yea thx for the tip.. gotta change my front and side mounts and lower ball joints too..
Old Aug 30, 2011 | 04:32 PM
ou sig's Avatar
Boomer SOONER
while at it you can remove the other fan the same way and then you can clean out the radiator. I just replaced my drivers side fan and was amazed how much dirt/crud was in the radiator. Makes since after 180k miles I guess... I took out the fans and sprayed water from the inside to the front and it really cleaned out nicely.
foxriderar77
Nov 19, 2020 10:17 AM
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
NSolace
Sep 3, 2015 08:02 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
