Girlfriends Car Idle's high and loud?
My woman has a mitsubishi galant that started to idle high when first started...
Does anyone know the cause of this? And what I can do to fix it besides taking it in and getting raped by the dealerships and such?
Moderator Alumnus
d00d...i deleted your other post because it is pretty much the same thing as this post and BOTH DO NOT BELONG in this forum. You should post this in OT because this have absolutely NOTHING to do with a TL. first/only warning....
Couldn't you have just moved it?
ISC (idle speed control) servo could be going South or there may be a vaccume leak somewhere. Does it stumble taking off from a dead stop? Does it ever come down? Ever had the trottle-body off the manifold before? Have you tried the adjustment screw on the throttle-body? Does the idle oscillate ~300rpm difference in gear?
There could be lots of reasons for this....
Moderator Alumnus
Originally posted by CP_ThunderGod
Thanks a lot dood...
Hau_nguyen91
09-06-2015 12:53 PM
