Getting no power to window regulator! Help!
i just purchased a new power window regulator for the front passenger side, but when i hook it up it still does not move! ive checked fuses (all good) and im not getting anthing near the plug either. i need help asap
Did new motor come with it? If it did just take it back.
Hey SEANcanBEAT, if you're not getting power at the passenger side window's motor switch, then the problem may be back over at the driver's side master switch. Check for power there, if none....then proceed to recheck fuse #13(7.5a) located in the passenger side fuse panel. For the driver's panel, check #9(7.5a) and #15(20a) fuses. There is also a relay located in the passenger side panel. My guess is that it's the master switch interlock.
xsilverhawkx
09-28-2015 06:51 PM
AcuraKidd
09-25-2015 11:18 PM
