gas?
gas?
where do u people fill your tanks?
i go to shell all the time...but it's starting to get a little high in prices...
i'm thinking costco...but is costco gas any different than shells?
there is a BIG differance
The TL requires Teir 1 quality gas- google it
Chevron Texaco Shell 76 all are of that quality standard and all have bonus fuel cleaner added to them.
You get better mileage and less garbage with the right gas.
Grin and bear it, or give up another vice to pay for gas
Check out www.toptiergas.com
What pisses me off is that up till last month I paid 10c more for mid-grade, and another 12c more for V power.
Now BP is charging 14c more for mid-grade, and additional 10c for premium.
Shell just jacked their V-Power to14c over mid-grade.
Friggin' legalized mafia that is government supported
Just put in premium (91 or better) from where ever you trust. Get used to the high prices as well. They are only going to go higher. Also where possible stay away from fuels with 10% ethanol
well then- by all means - spread that info with no facts to back it up!
Have you checked and learned the additives for cleaning like Techron come in the 91?
Azp TL- you cant say arco is fine until you run other gas IN the TL
I was an arco user on my truck and the TL for a short time after its purchase, until I tried the Tier 1 brands and noticed better mileage and cleaner running feel in both rides.
Acurazine info pays off again!
If you are comparing the differance between the grades of gas and worried over 1-2 dollars PER TANK!- especially since the lower grades/octane cannot be used in the TL,,,
what do you even CARE what they cost, only 1 number on the price board is of any concern.
Sell the TL right now and buy an econobox- you own a sports luxery car now-
it may be time for you to convert to a bicycle
seafoam has its uses. Its not an octane booster, but will clean that arco crud residue out!
There is a reason acura wants us to use certain things- clean gas is one of them.
The Shell commercial is real- that stuff is combustion byproduct and gets on the valve edge so they dont seal perfectly, and the piston is covered in crud instead of clean metal for better ignition of combustible materials
Use whatever makes you happy and we will all do the same
Now lets review what oil is the best in each persons opinion -ugh
or debate tire pressures or Tein SS dampening settings
I go to QT here in Kansas....Hey,u heard of a car "I Walk Z." and if everyone here in U.S. just all start walking to get around for awhile then maybe then the gas price might be very low...So,who is going to start making a message to everyone across U.S. to began walking or on the bike...
The way I see it is that using Costco gas shouldn't be a problem so long as you buy Premium (91 or higher Octane rating) and throw in couple bottles of Techrone a month.
Preferably put a can of Sea Foam in the tank twice a year.
Of course, if someone is cutting corners at a station and putting water in the tanks that's not at the fault of Arco. I've heard such stories about most of the brands.
Originally Posted by AZP-TL
The tag near the gas cap says to use premium gas, nothing more. Shell is overpriced and leaves residue like any other gas. The additives they advertise is marketing to justify the higher prices. Same goes for Chevron or any other company. I've used Arco for many years without any problems whatsoever and the few times I did use some of the so called better gases I noticed no difference whatsoever.
Originally Posted by red00tl
Costco gas ought to be the same as any Tier 1 company gas in your area except for the lack of additives.
If you are using a couple of bottles of Techron per month, you certainly aren't saving any money by using Costco.
Do the math
Originally Posted by S PAW 1
It's mostly the additives that makes it a top tier gas, and more expensive;duh!
Do the math
Do the math
The OP question was whether Costco's gas was any different from Shell's.
So I answered the question. The gas is the same, but no additives in Costco's.
Costco, however, sells Techrone at slightly over $2 a bottle, so two bottles a month is $4-5 of added cost.
Using Sea Foam twice a year should be around $13, so it's slightly more than a dollar per month. This is recommended by 01tl4tl even for those who use Tier 1 gas.
What I had said is not so much about how to save money, because you can't get something for nothing, but about clarifying what one should do to make sure that the car gets adequate amount of fuel system cleaning while using cheap gas with no additives.
for those who run arco for years and try 1 or 2 tanks of good gas- thats not going to be enough to clean the stuff out and make it run better.
The book does not say everything- look how old it is! Thats why there is acura.com, honda tech forums, service bulletins, acurazine and more. We dont make this stuff up - its tested by many members and reported back.
Everyone loved seafoam the old way, and we were only getting 3 of 6 cylinders. My car is better after using the correct direct vac port at the TB to get seafoam in the engine intake system. Thats step 1
Costco has techroline for 2 bucks- man its 10 bucks for enough to treat a tank in the states
"You forgot Car washing liquids or gascap turns"
No need- not a debated item
Doesnt everyone use steel wool pads and powdered dishwashing detergent for the car?
At least the gas cap has specific directions printed right on it!
Minimum 3 clicks
Minimum 3 clicks
Just for everyone's clarification Costco gas is actually Valero (at least in Nor Cal).
When i was waiting in line to fill up I asked the tanker truck driver where the gas is from and he replied the Valero refinery here in the Bay Area.
I have been using it for years and saving $2 per tank which is $100 per year - pays for the membership at least.
How long ago was that? I've heard Arco's gas was fairly cheap and low grade in the past until they were bought by BP in 2000.
I didn't know that. I always wondered
where they bought their fuel from.
Most of the UDF's (United Dairy Farmers) in this area are changing their name to Valero.
They are supplied by the Venezuelans/Chavez. There were so many boycotts, he decided to change the name in an effort to recover sales.
This is according to local news reports.
my 2006 TL 5AT only gets ~13mpg with non aggressive city driving. haven't broken 5k on the odometer yet. any insight? can i hope to see an improvement? my s2000 gets better mileage than this and I drive that like it was meant to be driven.
My 2004 I35 gets about 125 more miles per tank then my TL-S did ..... I was lucky if I was getting 280-300 per fillup, my I35 seems to be very very good on gas and I only use premium ..
As MPG I get 21 in my I35 and about 16-17 in my TL-S, groundzero your MPG is horrendous.
