Front-end issues.......
Old Aug 6, 2007 | 04:27 PM
shanedm99tl's Avatar
8th Gear
Angry Front-end issues.......
Hi all.
I need help.
I have a 99 tl. I am having problems with a loose front-end. I have replaced the shocks\struts and springs but the front-end still seems to be loose. When I say loose I mean that when I go down a bumpy road at a slow speed the front end will shake and rattle. My first thought was the shocks\struts.
Does anyone have any thoughts?
In addition I also have a humming in the front-end. I am not sure what this can be. I took the car to the dealer and they just kept giving me the same old "it is just tire noise" crap.. .. I have changed the tire and the rims three times and still get the noise. The faster I go the higher the pitch of the sound gets. I think it might be the CV joints.. (Had the bearings replaced by the dealer. at least that is what they told me and billed me for.)
Please help....
Thanks in advance for you thoughts..
G.
Old Aug 6, 2007 | 04:40 PM
acutee's Avatar
You may want to check you ball joint, ujoint, and humming could be from the bearing.
Old Aug 6, 2007 | 04:57 PM
fsttyms1's Avatar
huming usually comes from bearings or tires. I think i would find a different dealer. As for the other noise, typically thats ball joints
Old Aug 16, 2007 | 12:13 PM
8th Gear
Thanks for your help.... In addition I have found that the steering has a bit of play in it. is there a way to make it tighter?
Old Aug 17, 2007 | 09:22 PM
Cliffy99's Avatar
7th Gear
I am having similar problems with my 99, let me know what you find out... Just replaced struts and lower control arm on drivers side. I have a shaking at certain speeds (wheels just all balanced), pulsating under braking, and now grinding noise in reverse with wheel turned (CV Joint) I love Hondas but my love affair is waining... The lack of 'tightness' in the steering is a complaint that I have as well... Like I said let me know if you find anymore info...
abqtsx
1G TSX Problems & Fixes
36
Apr 21, 2019 02:19 PM
01cl_blk
Oct 3, 2006 08:46 AM
dreadnaught1181
Aug 9, 2006 10:01 PM
coop
Feb 18, 2002 09:13 PM
