Front end clunking. Figured out what it was.
#81
Originally Posted by Shaqs2002TLS
I take it you don't like taking your car to the stealership? After all that money, time and frustration it probably would've been worth a shot. Just have them inspect it for ~50-60 or maybe free. Little too late I guess.
Anyway , you deserve a congrats!!!![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
#82
Originally Posted by fsttyms1
My issue was 2 fold. One part was the rack, the other was the end links. Tierods shouldnt have much movement in them at all. They should be tight and require good effort to get them to twist (tops under 1/4 inch)
So can the tie rods on the power steering be changed or is the play from the rack itself?
I had a clunking sound in coming from the rear once and it turned out to be that dumbell looking part as the picture he posted That link but in the rear passenger side.
#83
Clunking
I had a clunking problem a month back, i would hear this annoying clunking noise during regular driving even if it wasnt a bump ... sound also came when i was turning...
mechanic replaced the links ... ( forget to ask him to elaborate) but he replaced the links underneath , and the car runs smooth and quiet as ever
#84
That dumbell looking thing is the endlink
#86
MP90 uninstalled
before changing the part, how did you decide it was the tierod ends? Mine are fine and tight from what I can tell but I am thinking this has something to do with the sway endlinks or sway bar. Possibly the upper arm hitting the fender well from bing dropped? I still dont know.
#87
Where can you buy the tierod ends? On the Acura parts websites I dont see them seperately.
![](http://www.acuraautomotiveparts.org/acura/jsp/mws/catimgs/13s0k0_b3310.gif)
#88
#90
i doubt mine is the rack, cause it clunks when i turn too.
im thinking mine is now endlinks or tierod ends.
i know its not the springs cause i changed out the springs for new ones.
its not the ball joints since they still look good and arent leaking.
as for the shocks, they dont leak but they do take a few seconds to rebound but this would be my second guess.
#91
Shocks, same thing. They dont have to be leaking to be bad. If they are original id bet they are probably past their life.
#92
Something is missing...my
Since this has become a general Q&A thread on driveability noises, I have one to throw in:
I have a strange noise that seems to happen, unrelated to speed, at a specific compression on the suspension noticed under braking (seems like left front). So, when I am installing my RT cat the other day, I notice that there is seemingly seepage from the LF strut. The question is, can a strut that is, as you said, past its life and leaking make a buzzing sound under braking due to loss of the hydraulic cushioning?
#93
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
I think alot of people need to realize these cars are getting old now. Even with low miles age is starting to take its toll on a lot of parts. And many of these parts should be starting to be replaced soon for many.
#94
Dude, i totally understand. I am just now starting to realize it. I have plans of H&R sport and Tokica's, but still wavering between the blues and the adjustable ones. Actually need to check my ball joints really well, but know that my tie rod ends seem to be good. Suppose the old creaky bones are starting to ache!
Thanks for your help.
Oh, do you know whether there would be a good advantage (aside from adjustability) to the adjustables. I haven't heard any complaints on the blues.
#95
Honestly with the miles we are all starting to get replacing the ball joints regardless isnt a bad idea. I prefer replacing the whole arm (upper and lower) due to getting new bushings with them as well. End links are another good one to replace with age. (as ive found out)
The blues are nice. Only thing nice about the adjustable ones is just that, being able to fine tune it. If your going to spend the money on adjustable ones i would go with the pricier koni yellows.
#97
Another nice thing about the yellows is they have an reversible perch for the spring to raise or lower slightly more
Oh and look here for control arms
http://www.macautoparts.net/Catalog....ategoryid=5900
#99
Originally Posted by bibledriver
Is that where you bought yours? You are pleased with them, I assume?
#100
Just because your balljoints look good doesnt mean they arent bad. You cant see a bad ball joint, and they really dont "leak" they can have a torn boot and grease coming out, but not leaking. ONLY way to know is to lift the car and apply pressure to them and yank and pry on them to see if there is movement.
not sure if these shocks are original but they are OEM so they might be. shocks would be what I replace after i inspect the endlinks and tierod ends. its just that i doubt the shocks are making the clunking/creaking noise.
#101
S E L L
my autoshop teacher helped me try to solve the problem by using a large pry bar and applying pressure to the joints on the lift. no noise came from them and no budge.
![Ponder](https://acurazine.com/forums/images/smilies/ponder.gif)
![Scream](https://acurazine.com/forums/images/smilies/scream.gif)
Kris, are the sway bar links load bearing at all? Or can I just unbolt them, put the new ones in and be done with it? I don't know if I should drive the car up on ramps or lift it with a floor jack. I'm thinking about doing the sway bar to frame bushings too since I'm gonna be in there anyways.
#102
jack the car up and install them. Some say to loosen the bolts and retighten them with the wheels on the ground. (you can do it with the wheel turned all the way one way. Or if you have 2 jacks place one under each lower arm with the wheels off and lift till the car starts lifting off the jack stands. that will place them close to normal ride height to tighten down.
#103
S E L L
#104
S E L L
I finally got a chance to replace the sway bar links today. Since I had to change the oil today, I figured I might as well change the links too. Finally!! No more clunking!
The right side link had a lot of play while the driver's side didn't have very much. I changed it anyway just to be on the safe side. I was going to use the OEM links but then I ran across the Moog replacements. Much beefier and I know they are quality parts.
![Clap](https://acurazine.com/forums/images/smilies/clap.gif)
#105
DIY coming???
#106
B93P TL Owner
End links are sometimes very hard to diagnose for this very reason. I've had this exact same scenario about a couple years ago, for about 6 months total! Nobody could figure out the noise (not even the dealer), as the endlinks didn't exhibit any signs of major wear. Finally I couldn't take it anymore, and went ahead and replaced the darn things. $40 and 30 minutes was all it took. Needlesstosay, haven't had further issues with the endlinks!
QUOTE=fsttyms1]Well i figured it out. I went in for an alignment today after putting in a new rack (well used cause mine had play in it) and while it was on the rack i was able to get under the car and play. With the car level and normal pressure on every thing it is the end links. When its jacked up they are tight as can be, and i could never duplicate the noise or find any play in them, But on the rack and weight on the suspension and things level i was able to get the noise out of them.
Oh and alignment specs no camber kit H&R sport drop are as follows.
Front
toe 0.0, -0.7 camber both sides
Rear
toe 0.1, -1.1 camber and -1.2 (what i would want to run even if i had a camber kit) <- no uneven wear from it.[/QUOTE]
Front
Rear
#107
S E L L
Originally Posted by 01tl4tl
DIY coming???
#109
S E L L
Originally Posted by mdavisii
Yep it took me about 30 minutes for both sides, and if memory serves me correctly I didn't even have to jack up the car!
![what](https://acurazine.com/forums/images/smilies/what.gif)
#111
'02 TL-S
I had an annoying clunking noise coming from the right front of my TL(150k) and finally figured out what it was by jacking up the right front so the tire was off the ground, then put the jack under the lower control arm with slight pressure.
Then I grabbed the wheel and tried pulling/pushing on it to recreate the "clunk". Turns out it was the upper control arm bushing rattling away. I found one for an accord on ebay for around $20-30 new.
Problem solved!
Problem solved!
#113
I've been working on this. I replaced the sway bar bushings and the tie rod end links. The nose is greatly reduced and the front end is TIGHT like new.
Yet, still on the crisp, sharp bumps I get the clunk.
#114
i guess mine must be worn out shocks as it makes clunking noise over bumps. and this started after i switched out the stock shock and springs and installed coilovers. Do you guys still think it could be the endlinks? I know what a blown shock behaves, but when i push the car to test the shocks, it doesn't seem like it's blown, as it bounces back up pretty quickly and it doesn't make multiple up and down movements. push it once and it'll bounce back up and that's it. Any suggestions?
#115
S E L L
#119
WNC Real Estate Sales99TL
My front pass. tire was wearing bad when I switched to Yoko's. I asked around about who did good alignments. The car's steering was not real tight. The alignment guy found a bad outer front tie rod on my steering rack. Replaced em both and now=no wear. OH=The Acura garage didn't find the problem. I took it back 4 times and they said = "Nothing is wrong." The alignment guy at the Acura Garage was a jerk to me, telling me nothing was wrong with the car. If you jacked up the front of the car and tapped the front passenger wheel you could hear and feel the play in the tie rod. Was about $200 to replace em both.
#120
aznboi2424 Hard to tell from the pic and if its what your asking but thats part of the subframe.
