Front End Accident
Guest
Posts: n/a
![Angry](https://acurazine.com/forums/images/icons/icon8.gif)
Hi all,
I just got into a collision with a stationary car. I ended up hitting the rear of the vehicle in front of me. Speed seemed to be about 10mph. The front bumper is damaged, the hood is slightly pushed back, the drivers side headlight lens is cracked.
Everything else appears OK. The hood still opens and the radiator, engine, etc appear OK. The underside of the bumpers is intact. The airbags did go off! The car runs and steers fine.
I will be needing to get this fixed. My question is, is there anything special I should be looking for in terms of hidden damage? Any hints on what to expect?
Thanks,
PS Everyone was OK
Thanks,
PS Everyone was OK
I would check for oil leaks and especialy coolant leaks. Just leave white paper under the car when parked and let it cool over night. Leave the paper and park in the same spot over it for a few days. PINK-red is tranny fluid, light - dark brown is engine oil. Neon green is coolant. Dont run the AC so you don't get throne off by the water discharge. Make sure winshield washer tank didn't crack since it is right behind the bumper on passenger side. If you can run a clean white rag over the brake lines especially where the the ends to see if perhaps they were loose and are leaking now just to be safe. That should be a good indication of whether or not there is damage besides cosmetic things.
Do you live far from NYC. I have several front end parts like Stock bumper and absorber boxes and styrofoam cross pad. I want to get rid of them. What color is your TL?
OG
If there are no leaks, then you other only concern is to check for any frame damage. If you have never done it before, there is an easy way. Look at the gaps between the fender and the door. Are they consistent from top to bottom? Are they the same on the left side and the right? If the gaps are a little off, you probably have some minor frame damage. If there are no gaps at all, you know you have some frame damage. Good luck.
Guest
Posts: n/a
Thanks for all the input!
No evidence of any fluid leaking. No change in the gaps of either front door or where the front quarter panels meet the "A" pillar so I'm hoping no frame damage. Maybe when they replace the driver side airbag they can use a newer on with the emblem.
I will be getting an estimate from a shop in Manchester CT that I trust. They do superb body work. They are known for their restoration work of older Corvettes and have restored many 100 point cars. They have fixed several friends vehicles.
Guest
Posts: n/a
The car is in the shop. Front Bumper, hood with grill, airbags, one headlight assembly, one wheel and a bit of paint. No frame damage apparent, but will be put on a machine which very accurately determines alignment. Total 5K!
I'll let you know how it comes out.
5k seems alright considereing my damaged cost came out to be $4800 when my headlights got stolen! They had to fix the bumper, both side fenders and inside wiring, hopefully I can pick up my baby this weekend
BlingBling INSPIRE 32V
Originally posted by thephantom
I got into a minor accident 6/30/01 and my air bags did not go off, total damage... $9K+. Our cars are not cheap to fix.
![](http://www.acura-tl.com/ubb/eek.gif)
Originally posted by songoku
$9k damage w/o airbag??? You call that minor???
I was a 15 MPH impact and no one got hurt, that's why I called it minor. They replaced EVERYTHING, my whole frontend is new. The hood was around $500, the HIDs were like $1200, also, there was frame work done and they did a wonderful job.
![](http://www.acura-tl.com/ubb/rolleyes.gif)
Is it because it wasn't too fast??
Guest
Posts: n/a
![Smile](https://acurazine.com/forums/images/icons/icon7.gif)
I finally got my car back!
The shop (Restoration Shop, Manchester, CT) did a great job. The diamond white pearl matches perfectly and is of better quality than the original paint. They had to use a 2000 airbag rather than a 2002 model because they need the VIN # to get a replacement. (so no logo or improved horn action...oh well). I keep my car quite clean, but they also detailed it before returning it.
It is nice to have it back!
TLDude876
12-28-2016 03:18 PM
Oakes
Wash & Wax
10-12-2015 11:17 AM
