front corner lights
Old Sep 9, 2001 | 08:20 PM
front corner lights
I know that the front corner bulbs are double filament put can I put single filaments bulbs in them? I am asking this because I currently have Polarg double filament bulbs in the front and I don't like the look when not blinking. I am even thinking of changing back to the stock orange bulbs? Also, can I remove one of the things on the back of the bulb so it only blinks white and blank when not blinking? Is this legal?
Old Sep 9, 2001 | 10:59 PM
3point2TL's Avatar
y do this? i say you change it to orange. its not legal, but i don't think anybody wuold noitce. btw if you want it to only light up when you signal, just look for the green wire connecting your signal and cut it. this will howerver make your lights blink fast.
Old Sep 10, 2001 | 12:00 AM
hooked2TL's Avatar
You can just cut off the "inside" pair of wire contacts on a double filament bulb to have it function as single filament. Doing this, you only use the "shorter" filament inside the bulb, and will give you your on-off feature.
Feb 25, 2020 09:57 AM
08 NBP TL
Sep 8, 2015 08:49 PM
voigt
Sep 2, 2015 10:44 PM
bymotion
Aug 31, 2015 05:00 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
