Fog light mod (Alternate version)
Old 07-09-2009, 02:52 PM
  #161
Low & Slow w/Dubz On My
ZEUS'O3TL's Avatar
Originally Posted by '02_TL-S
Hey Zeus..how are those 5000k on output? I wanna go with the Phillips 85126+ and I've read they look like 5000k...I like the stock output and don't wanna lose light..even tho I have already cuz of the age of my bulbs (stockies)
..X2..
they are wonderful man...i bought some 8K for the hell of it and a week later i went back to my 5K's....i have heard what you listed above as well so go for it and when you first get them your gonna want to drive only at night so you can light the road up...
Old 07-12-2009, 10:28 PM
  #162
tiger2kn5's Avatar
I finally got around to putting in that add-a-circuit and everything went smoothly (had that SRS problem, but took care of it).
I did notice that the fog lights turn off when I put my high beams on, is that normal, or did I do something wrong here? I am not too sure if that was also the case prior to using the add-in-circuit technique.
Old 07-13-2009, 10:32 AM
  #163
Hondanutty's Avatar
Nope, you are ok... it's supposed to do that!
Old 07-13-2009, 04:24 PM
  #164
Traded in my
'02_TL-S's Avatar
Originally Posted by ZEUS'O3TL
..X2..
Sweeet..I'm pullin the trigger Also found HID kit for the fogs with bulbs for pretty cheap so crackheads on the side of the road..prepare to be seen!!! Man, I think Ima become nocturnal just so I can enjoy these upgrades...
Old 07-20-2009, 04:37 PM
  #165
orbie's Avatar
anyone in San Antonio, Texas that has done this mod?
Old 08-15-2009, 04:24 PM
  #166
alhalljr1980's Avatar
Old 08-16-2009, 04:29 PM
  #167
skipwillson's Avatar
Does anyone know of a way to do the fog light mod so that the fog lights don't turn off with the high-beams on? I just did a similar mod to our new-to-us '97 Explorer and the fogs will stay on even with the high-beams. I also did it on my previous car, a '95 Probe GT. I assume it's doable on the TL too.
Old 08-16-2009, 07:45 PM
  #168
It's the Halladay season!
hANDYcaptd's Avatar
It's doable...jjashaa did it. But if I remember right, he said something about a lot of wires have to be cut and such...
Old 09-19-2009, 03:17 AM
  #169
USDM -> JDM
AZN.M3NACE's Avatar
okay so i bought the stuff that is needed for the mod, but i have a question. do i need to solder the diode to the wire? and how many of the diodes do i need to use, one or two?
Old 09-19-2009, 09:33 AM
  #170
Hondanutty's Avatar
You only need one diode (it keeps the power from feeding back through the circuit). You don't have to solder the wires, but it does give a better connection. Butt connectors work as well, just make sure you have the ends crimped securely.
Old 09-20-2009, 12:18 AM
  #171
USDM -> JDM
AZN.M3NACE's Avatar
yay! i did it =)
Old 09-20-2009, 12:26 AM
  #172
'13 Hyundai Sonata
TLin401's Avatar
^I thought you said that you were selling the car.
Anyway...
Looks good, gives me an idea now for my 1G so that I can master my fog light mod so that I don't have to push the switch every time I want mine to be one.
Old 09-20-2009, 04:22 AM
  #173
USDM -> JDM
AZN.M3NACE's Avatar
Anyway...
Thanks.
I was going to sell the car, but things changed because I was finally able to get AAMCO to put 7year/Unlimited Miles warranty on my new tranny. So, new tranny lasting that long means keeping it for awhile...... plus the time is great to buy a new car, but iunno about keeping my job and my name in payroll long enough..
Old 09-21-2009, 04:27 AM
  #174
USDM -> JDM
AZN.M3NACE's Avatar
Anyone experience the SRS light coming on after or a few days after doing the foglight mod? I had my SRS light come on but took care of it by resetting it myself =D
Old 09-22-2009, 11:59 AM
  #175
Traded in my
'02_TL-S's Avatar
^ Nope..been a few months too. Check to make sure no wires are exposed and everything is plugged in correctly..just in case.
Old 09-28-2009, 01:59 PM
  #176
Linkers033's Avatar
Anyone from Mineapolis, MN area who has done this?
Old 10-28-2009, 06:23 PM
  #177
02 type s's Avatar
Anyone in Albany, NY do this mod? Or anywhere in upstate NY for that matter?
Old 07-16-2010, 12:22 AM
  #178
Wr00m's Avatar
I just did the mod a couple of days ago. I didn't use the diode and connected the fog button to the fuse#9 (ACC I believe) through an add-a-circuit. Mod worked fine when I tested it but for some reason it screwed my sound system a little. I have an aftermarket head unit and a single din touch screen, 3 amps(front, rear and sub) and all aftermarket speakers and a sub in the back. So when I turn my ignition on before starting the car my speaker and sub work as usual. When I start the car my speakers work and the amp for the sub turns on but my sub does not play.
I could not figure out why it's doing it so I found an alternative way of doing a fog light mod and so far I like it.
I'm in Canada so I've got DRL(day running lights). So I connected my add-a-circuit to a day light fuse(don't remember the number but it's indicated on the fuse cover). So I can still turn the fogs on and off any time i want. When the car is running I get my DRLs on and fogs on(or off if i want). Same when I turn my side markers and tails, I get side markers, DRLs, fogs and tails on. When I turn on my HIDs, however, my DRL turn off and I only have the sides, HIDs and fogs on. I can still use high beams and when I do that fogs turn off.
My version of the mod is fine but I'm still interested to find out as to why my sub was not working with the V2 mod. Was it due to not having the diode in the circuit? If that's the case then why would my door speakers work? I have a separate amp for the front and the back stage and they are on the same circuit with the sub amp.
Let me know if you have any ideas.
Thanks and sorry for book-long post.
Old 08-31-2010, 11:20 PM
  #179
ecaf005's Avatar
i know this thread is old...but anyone in nyc done this that can help?
Old 12-04-2010, 04:31 PM
  #180
02TL4ATL's Avatar
finally got around to doing this mod, easier than i thought it would be.
Old 12-04-2010, 11:54 PM
  #181
6th Gear
lconroy213's Avatar
can't you just wire them up like you can with integra's? On my old integra i just wired the power that runs to the fog light switch into the power to the rear defroster which gets power whenever the ignition is in the run position, then you can turn them on at will regardless of the headlights or running lights.
Old 12-30-2010, 12:03 PM
  #182
Need an OEM lip kit on my
JRhodes88's Avatar
Can anyone show me what the "tap" things look like? I was just in Radio Shack trying to pick some up but I couldn't figure out what they were.
Old 12-30-2010, 03:14 PM
  #183
JRhodes88's Avatar
Nevermind...I found them at the shack and the mod was way too easy.
Old 12-30-2010, 10:26 PM
  #184
JRhodes88's Avatar
Lookin good
Old 12-30-2010, 10:29 PM
  #185
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
About High + Fogs
Done, Its very Simple. Here´s my kinda "DIY": https://acurazine.com/forums/2g-tl-1999-2003-98/diy-high-beam-fogs-mod-802817/
Old 01-07-2011, 02:26 AM
  #186
02TL4ATL's Avatar
if anyone is still having difficulty doing this mod, then here is a quick video on how to do it. not the best but i tried the audio isnt really clear but is still audible.
http://www.youtube.com/watch?v=dvdvbylYZc0
Old 01-07-2011, 07:31 AM
  #187
JRhodes88's Avatar
Nice video, it's pronounced "DIE-ODE"
Old 01-07-2011, 11:35 AM
  #188
02TL4ATL's Avatar
haha yea my bad, i was in a rush.
Old 01-07-2011, 11:52 AM
  #189
floored4door's Avatar
Probably the easiest mod on the planet IMO. Thanks to this thread of course! Good shit!
Old 01-10-2011, 07:11 PM
  #190
Bxscig's Avatar
Nice job! I never got the time to do something like this.... Nice to see even after 5 years people there are people that still like this... Glad I am still hosting the pictures then.
Old 01-10-2011, 07:15 PM
  #191
Bxscig's Avatar
If you are still reading this... I am not exactly sure why it wasn't working but I recall the reason I added the DIODE was because current was flowing backwards and still powering parts in the car which isn't good. I added the diode afterwards when I saw I still could power my ACC items if the fogs were on.
Old 01-10-2011, 07:17 PM
  #192
Bxscig's Avatar
Same concept is just that I wanted to add a fuse as well as a diode so that current only flows one way.
Old 01-10-2011, 07:18 PM
  #193
Bxscig's Avatar
Are you still looking for someone? Where in Brooklyn?
Old 01-10-2011, 07:19 PM
  #194
Bxscig's Avatar
Its been a couple of years but this happens if you pull the wrong fuse while the key is still in the car... or at least that is what happened to me. Reset it and it never came back.
Old 04-05-2011, 10:38 PM
  #195
Los510's Avatar
I know this thread is old but I've been searching how to get HIDs in for fogs and i saw AZN.M3NACE's picture of his 03 tl with the hid fogs. I have a 01 CL-S. Can anyone share some knowledge on what type/size of HID bulb you used for your fog lamp housing? And anyone have any ideas on how i would wire it up? ANY info would be greatly appreciated!
Old 04-06-2011, 12:20 AM
  #196
mestizoracer310's Avatar
Don't quote me but most likely a 9006. I checked Sylvania.com's replacement guide and I didn't see any listing for the fog lights...
Old 04-06-2011, 06:16 PM
  #197
Bxscig's Avatar
I don't believe they are 9006 but like the guy above said, check the site forth right bulb when purchasing tje HID kit. Most of them come with a relay and it is really straight forward. Power ground and trigger to relay, then from relay the harness provided so go directly to the ballasts. Power to battery power, ground to any ground battery chassis, trigger just tap the original fog light harness.
Old 04-07-2011, 09:48 PM
  #198
Los510's Avatar
So i checked the site and nothing. I have Road lamps on my CLS. Not fogs like you guys with Tl's. But my the road lamp bulb size is 921, and i don't think i can find hid bulbs that small right?
Old 04-08-2011, 05:53 PM
  #199
Bxscig's Avatar
If the bulbs are 921, check on eBay to see if they have that size. The other option would-be to retrofit it. If they don't you may be out of luck. I haven't been on the forum much in the past few years but I don't recall anyone added it but since then there are a lot more HID kits on the market.
Old 04-09-2011, 07:05 PM
  #200
Los510's Avatar
yea im going to check on bay today. But i guess im going to have to custom fit and wire some hids in there. Any suggestion on how to wire them? I know im going to have to get power from the battery directly with a relay. But any suggestion on how to turn them on/off? Maybe i can use a TL fog switch somehow?
Quick Reply: Fog light mod (Alternate version)
